Old 05-06-2016, 07:09 AM   #1
Portland , Oregon
Hehr Frames Heavy Oxidation
I have a 1952 Silver a Streak Clipper. It has 1 original Dual Pane Hehr Standard. I bought a Single Pane Hehr Standard off EBay. I have 2 Matching Hehr Jalousies, early to Mid 60's?
I am using Nuvite 9,7, C , and A.
I need more grit. Some external Oxidation chunks need I would assume is a heavy cutting compound that is aluminum safe. Recommendations ?See photos of EBay frame and Jalousies Frames.
I can't wait for some Nuvite 10. I have Industrial Paint Supply Shops...So 3M and Maguire stuff is available locally.
bikeukeguy is offline   Reply With Quote
Old 05-29-2016, 01:54 AM   #2
1954 22' Flying Cloud
Kirkland , Washington
What was your solution? I'm working with the same heavy oxidation, and even F10 isn't getting the desired results.
54fuselage is offline   Reply With Quote
Old 05-29-2016, 06:47 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Get a small 3M "flapper wheel" type paint and corrosion removal tool....cheap....and hit all the frames with it before the polish. I also use aluminum wool and fingers to get the corners and as a final clean up.
Old 05-31-2016, 12:48 AM   #4
The 3M wheel did work well in removing the corrosion. I had tried many different dremel wheels and nothing worked nearly as fast as the 3M, but the trade off is deeper scratches a little beyond my comfort level since I'm working with Alclad. On the plus side this was only necessary on the upper hinge area, so it looks more brushed than polished at this time and I may just leave it that way.
Heavy Oxidation monocoque Cleaning, Stripping & Polishing 179 03-08-2016 07:33 AM
Removing HEAVY oxidation from Jalousie Windows bass-o-matic Windows & Screens 1 07-03-2014 03:31 PM
GOJO! First cut for heavy oxidation muddy_hollow Cleaning, Stripping & Polishing 11 06-22-2010 01:52 AM
Does oxidation cause oxidation bmklawt Ribs, Skins & Rivets 9 02-09-2009 09:21 AM
Heavy Oxidation #2 cuyeda Cleaning, Stripping & Polishing 10 06-11-2008 04:31 PM
