Old 05-29-2008, 04:27 AM   #127
Baltimore , Maryland
Originally Posted by Fyrzowt
Festool
Dave, I have been slowly making the transition over to festool. It wasn't until your post that I realized there is a polishing aspect to my sander. I will have to look into that, but not before the weekend. We are attending a rally this weekend and all polishing is on hold.
Old 05-29-2008, 05:47 AM   #128
Festool? I thought he was insulting you with some medieval taunt. This is like some cryptic language to me.
Anyone care to explain the meaning of this??
Old 05-29-2008, 06:19 AM   #129
Images: 59
Here's a Festool. . .
Old 05-29-2008, 07:01 AM   #130
Thanks Mark.
Wow, 446 bones. That makes a Cyclo look cheap.
It appears I'll be haunting the pawn shops or *gasp* Harbor Freight for the near future...
Old 05-29-2008, 08:17 AM   #131
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I figure I'm a fairly balanced guy - I have one Festool and one Harbor Freight
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-29-2008, 10:30 AM   #132
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
a fez-tool method of polishing
Dave
Dave, I was beginning to think you had taken up wearing a fez while polishing your trailer more like a whirling dervish! If this is so possibly you have rediscovered the oldest known technique of polishing a trailer!
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 05-30-2008, 12:30 PM   #133
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I think I will stick to my pneumatic Cyclo,my compressor can only give me about 20 min at a time,so the cyclo and I ,don`t get that over heated.There is an advantage to having too small of a compressor.Dave
easyride is offline   Reply With Quote
Old 06-07-2008, 09:39 PM   #134
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
I tackled the foremost panel today by hand wet sanding with 340 grade wetordry paper. Here's the result using only the 340 so far. It sure loves to eat the heavy corrosion! Took a couple of hours.
ID:	61972   Click image for larger version
ID:	61980   Click image for larger version
Todd
Old 06-08-2008, 02:49 AM   #135
Boy oh boy, Todd I will totally stop whining about how much I hate polishing. I am up against nothing compared to your filliform corrosion. That is some serious stuff you are going at. Keep up the good fight.
Old 06-08-2008, 03:45 AM   #136
Over59's Avatar
Putnam , Connecticut
Images: 37
These guys have some stuff that may deal with the acid rain residue and steel wool residue problems. Finish Kare FK1 Professional Detailing Products
Over59 is offline   Reply With Quote
Old 06-08-2008, 09:07 AM   #137
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Thanks Frank, now you see why I'm fond lately of calling this trailer the "black pearl!" It has a serious case of filiform corrosion but as you can see it's coming right out with the wetordry paper. One panel at a time...
Todd
Old 06-08-2008, 09:14 AM   #138
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Paul, do you have any pictures, preferably worst case scenarios, you would care to post of what acid rain residue and/or steel wool residue problems look like?
Todd
Old 06-08-2008, 10:17 AM   #139
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Here's SilverGate's recent article on filiform corrosion problems on the newer Airstreams on the Airstream Life website: Filiform corrosion Very informative, lots of tips, and links. If you apply this knowledge correctly maybe you can save yourself the troubles of correcting extreme corrosion.
Todd
Old 06-08-2008, 08:27 PM   #140
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
Negligence
OK, I have been promissing picture so my oxidation and the current status. I spend the weekend sanding all over and have some pics.
The upper left is the difference showing the front cone and the side. The front cone on the upper right had bad filoform also, but I sanded it down. Note that although my aluminum still looks pretty and reflective, it is not al-clad and will not mirror.
Middle left, I am re-doing my stripe also. Having it painted on this time, as I am never peeling it again. I found a good process to strip the tape that wasn't degraded on the forums, but anything that was degraded from the sun wouldn't come off easily. On one of the trips to the body shop supply store I found an "erasure" type of attachment for the drill that erased it right off. I will post the name and pics for that on another forum. Middle right and lower are both aluminum trims that have substantial filorom. The electric cover has been sanded an looks good. The wheel well trim is real bad, also.
Name:	Imported 050608 013.JPG
ID:	62039   Click image for larger version
Name:	Imported 050608 014.JPG
Name:	Imported 050608 008.JPG
ID:	62043   Click image for larger version
Name:	Imported 050608 016.JPG
Name:	Imported 050608 017.JPG
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
oxidation anyone? nettepdx Cleaning, Stripping & Polishing 5 04-01-2009 11:35 AM
Oxidation ? wohtex Cleaning, Stripping & Polishing 3 04-14-2006 08:31 PM
Heavy Enough - go big or go home GT1963 Tow Vehicles 3 02-19-2005 06:57 PM
Oxidation davthr Cleaning, Stripping & Polishing 0 02-09-2003 08:06 AM
oxidation don m Cleaning, Stripping & Polishing 4 09-25-2002 05:17 PM
