Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 04-07-2008, 10:53 PM   #1
greenrig
Profile:  1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
having trouble with my cyclo technique
compounded with f7. then removed the residue. compounded with C, then removed the residue. now i am using the cyclo with C to remove the swirls. but the cyclo leaves residue that cannot be buffed out. i did a test spot with the final S grade and its pretty much the same thing. it moves the residue around but cannot be buffed out. i think my mistake is the micro fiber cloth i am using with the cyclo. i am not using the bonnets or cotton towel but micro fiber towels. i thought they would be better because they dont scratch. do you think this is my issue? my other thought is this is a residue from using mineral spirts inbetween grades of polish or maybe light traces of soap from washing the the wool??? what do you think??
one more question. if one uses the towels with a cyclo, they prevent the heads from spinning but not vibrating. is that the idea?
greenrig is offline   Reply With Quote
Old 04-07-2008, 11:26 PM   #2
goransons
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
Yakima , Washington
not an expert but have made plenty of errors. I wouldn't imagine the microfiber would do well with the f7, because you do want some courseness to the material to help mechanically remove the oxidation. I had similiar problems sometimes, and I usually attributed it to applying too much compound and it drying out on the surface before it buffed off. Sometimes had that problem when it was too cold out, and if I let it sit on the surface in direct sunlight and it dried.
goransons is offline   Reply With Quote
Old 04-07-2008, 11:26 PM   #3
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I think you are on the right track. You need to use the cotton wraps on the cyclo. The micofiber is for cleanup.
When you use the cyclo with the cyclowraps you start with the same grade polish of the last compound. So if you compounded with C then you start with C on the cyclo. Only use a very small amount on each head, about the size of an M&M candy. Move the cyclo quickly in every direction and keep going until the black oxidation is cleaned up with the cyclo.
You will have to change to a clean spot on the cotton cloth every 2' x 2' area cyclo'd.
Clean the area with mineral spirits and the microfiber between polish grades.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 04-08-2008, 08:17 AM   #4
greenrig
1959 18' "Footer"
thanks. i think my mistakes are: i moved the trailer out side for better light (so i could see the swirls disappearing -or not) but maybe the nuvite had a chance to dry. 2nd is that i am using way too much nuvite -maybe i was using Peanut M&M's and 3 of them! 3rd i am trying to cover way too big of an area. and 4th is the micro fiber instead of cotton.
those microfiber towels felt so sweet and were a good price at costco, i couldnt resist. costco also has 'cotton' auto towels but does not list what percentage of cotton they are. has anyone had any experience with these towels -from costco??
last question being about the heads of the cyclo moving freely behind the wraps?? or just vibrating/orbiting not spinning -like they want to.
Old 04-08-2008, 08:40 AM   #5
Area63
Area 63 Productions
Commercial Vendor
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
The heads of the cyclo are not spinning when you wrap them with the sweatshirt material. They just wobble randomly about.
I recommend you get the wrap from Perfect Poish. It really works well, and is laid out perfectly.
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 04-08-2008, 08:46 AM   #6
jbond
jbond's Avatar
Profile:  Shalimar , Florida
Images: 13
I recommend you use sweatshirt material with the soft side out to wrap over the cyclo heads. Also read and follow these details:
Using the Cyclo Polisher
Using the Compounding Polisher
If you use the right amount of polish you will not have to do much if any cleanup between after polishing a 18"-24" square. Polishing is counter-intuitive. Normally we think that if one dab is good two is better. Polishing works the other way. Think "less is better". The same holds for speed of your compounder, slower speed is better.
Herb
Wally# 1861
Prez VAC
63 Globetrotter Patty 62 Overlander Doc
63 Suburban Andy 63 Overlander Tex
jbond is offline   Reply With Quote
Old 04-08-2008, 09:02 AM   #7
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
It should probably be mentioned that when using S polish you use even less than other grades - so those M&M dabs should be even more spaced than the other grades - less is really better.
Ken J.
1958 Overlander
Ken J is offline   Reply With Quote
Old 04-08-2008, 09:51 AM   #8
1953 Flying
1953 Flying Cloud
1953 Flying's Avatar
Profile:  1953 21' Flying Cloud
Sacramento , California
Images: 8
I'm in the process of using the cyclo with c grade. I do not use mineral spirits between each nuvite grade. the mineral spirits leaves a residue. what I found the best to remove the excess polish is corn starch and the micro towel. I just dab the towel in a small container and wipe away the excess. Hope this helps.
_______
Robert
Life is like a roller coaster, a whole lot of up's and down's..
1953 Flying is offline   Reply With Quote
Old 04-08-2008, 09:53 AM   #9
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
NO! Don't use terry cloth towels...they are much too coarse. Use the 100% cotton sweatshirt wraps and technique that Herb recommended.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 04-08-2008, 10:05 AM   #10
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
On the other hand...
I used the Costco cotton towels with good results.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 04-08-2008, 10:12 AM   #11
greenrig
1959 18' "Footer"
thanks for all the input. i'm off to the shop to see if i have a more productive polishing day with the cyclo. -after i raid the baking cupboard for some cornstarch.
Old 04-08-2008, 10:56 AM   #12
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Dave
Looks like you did have good results Dave...my only concern would be if the polishing compound builds up & dries out in the loops of the terry cloth it could scratch the aluminum. If you keep using lots of clean towels, it's probably okay...but the sweatshirt material has less chance of caking up.
greenrig, as you have probably noticed, you will find as many different opinions and techniques as there are polished trailers! The bottomline is, figure out something that works for you and go for it!
Shari
Old 04-08-2008, 11:07 AM   #13
Fyrzowt
Fyrzowt's Avatar
Images: 8
Shari
Shari brings up a good point. No matter what technique you try, you will have to experiment with things to see what gives the best result. More compound, less, etc.
Shari, I did frequently change towel positions. I rotated the towels 90 degrees, then flipped them over and did the same. That gives you 4 positions for each towel. They are cheap enough to throw away. I did wash one batch of towels but found it too much hassle.
Dave
AIR #15800
2000 Safari SS 25'
Old 04-08-2008, 03:43 PM   #14
greenrig
1959 18' "Footer"
i getting pretty good results with the terry towels and multiple change outs. i am currently using C grade nuvite but has anyone used these towels with final finish C?
When is a Cyclo not a Cyclo? RichardT Cleaning, Stripping & Polishing 11 01-29-2006 04:05 PM
Final Floor Replacement Technique JohnG Repairing/Replacing Floor &/or Frame 46 01-15-2006 04:43 PM
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 10:09 PM
Need Cyclo Help! Bryanhu Cleaning, Stripping & Polishing 3 11-04-2004 11:03 PM
Questions on riveting technique 74Tradewind Ribs, Skins & Rivets 6 05-24-2002 10:45 PM
