Old 09-22-2006, 09:27 PM   #1
ernesto ca's Avatar
1994 34' Excella
Arabela , New Mexico
Have top half pine sap problem
I am looking at a 98 Safari...apparently, the current owner had it stored under some pine trees off and on for a couple of years and the sap dripped on the top half, I am looking to see if " walbernizing " is sufficient to get it back to luster...Help...I am in the process of making an offer this weekend just want to make sure the exterior can be broght back without a major investment....Thanks. Ernesto
ernesto ca is offline   Reply With Quote
Old 09-22-2006, 09:33 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Ernesto -- I got a fair number of returns when I entered 'pine sap' in the search field. I would suggest that while you await any other replies.
Walbernize is only a liquid wax concoction. It helps protect intact clearcoat and by itself would probably not address the pine sap issue. The challenge will be removing pine sap with the least damage to clearcoat.
Best wishes in your Airstream search!
5 meter Langford Nahanni
Old 09-23-2006, 04:43 AM   #3
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Vegatable Oil
I found a recommendation on this site to use vegatable oil to rub out the pine sap. I tried it and it works!
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 09-23-2006, 06:00 AM   #4
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Go to a local auto body shop or auto body supply store and ask them, we use to keep some stuff where I worked that would take it off and not damage paint. Didn't use it every day so I don't remember the name.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Low Voltage Problem kellyw Electrical - Systems, Generators, Batteries & Solar 3 10-23-2002 06:35 PM
Opps... (Split thread problem) Andy R Our Community 1 10-19-2002 02:12 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
