Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 12-10-2007, 08:15 AM   #1
Perry
pezz
Perry's Avatar
Profile:  1982 34' Limited
mire poix , midi pyrenees
Has Any One use microbille on clear coat?
Has anyone used a sand blaster with microbille to take off clear coat ?
microbille are very small plastic balls
perry
PERRY
First European Airstream park http://www.airstreameurope.com
Perry is offline   Reply With Quote
Old 12-10-2007, 11:28 AM   #2
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Interesting question.
My first reaction would be the bead blast would leave a matt finish that might be harded to polish out than the original clear coat removal by polish.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 12-10-2007, 11:40 AM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I've seen a trailer that was blasted with walnut shells...it left a very nice matte finsh. It would be suitable for re-clearcoating, but not polishing without some extra effort. But then polishing is a lot of effort to begin with...
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 12-10-2007, 12:02 PM   #4
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Beads, walnut shell particles & soda have been discussed here. I believe one member documented success with soda and using somebody who had worked with aircraft. Even without producing heat buildup there is a significant problem with permanent warp developing from any type of blasting. I am imagining some mechanism of burnishing altering the dimension of one face, thus producing the permanent warp.
My input isn't the important part of these threads. They were just easy for me to find with our search function:
http://www.airforums.com/forums/f4/p...oval-6285.html
Paint
http://www.airforums.com/forums/f310...tml#post308722
I've personally used walnut shells on several samples of aluminum. The finish is very matte and I believe that alone would concern most owners. And yes, the warping was very noticeable!
Old 12-10-2007, 03:17 PM   #5
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Rice hulls are used for blasting in the log home restoration process, but these may also warp aluminum. I would lean toward chemical strippers.
Fyrzowt is offline   Reply With Quote
Old 12-10-2007, 03:30 PM   #6
Rollerboy
Profile:  1970 25' Tradewind
Gaylord , Michigan
you may want to see if there is a dry ice blaster near you in the yellow pages no heat and it will remove the clearcoat....check it out !
Rollerboy is online now   Reply With Quote
Old 12-10-2007, 03:42 PM   #7
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I've blasted alot of aluminum in my career with many different medias, such as walnut shells, silica glass beads, coal slag, play sand, soda, etc. and the results very depending on what you are trying to accomplish. I have never seen 2024-T3 distort if done by a competent person. Don't dwell on one spot, watch your air pressure and nozzle size. Blasting will remove alclad quickly and will leave a very dull finish. It is mostly used in the avaition industry to remove corrosion, and this it does well. I know that experiments were tried using dry ice beads but I do not how it worked out. If I were prepping an Airstream for painting I would most likely blast it, But to remove just clearcoat I would use a chemical stripper. Blasting just would not be worth the extra effort protecting the areas not needing blasted like windows and such.
