02-22-2012, 10:12 AM
#21
1965 20' Globetrotter
1955 22' Safari
Butte
, Montana
I'm going to buy a polisher soon and was thinking of starting this thread myself.
I plan to use the buffing wheels and bar as in this video. If you have used this process, what polisher would you recommend? I think the guy in this video is using a Makita, wich is a little cheaper than DeWalt or Milwaukee. From reading this thread, I probably won't buy Harbor freight because I want something more reliable.
So, what do you recommend? Is one brand lighter in weight, but still robust enough to last? Is there a brand that is a better value? Should I get a different polisher for the buffing wheels as opposed to the pads that Perfect Polish sells? Is DeWalt the absolute best or is something else just as good? I'm just want to make an informed decision so that I don't have to buy a second polisher. Thanks!
02-22-2012, 10:15 AM
#22
1966 26' Overlander
Woodstock
, Georgia
I have polished 3 trailers with a harbor freight variable speed buffer. The same one. It still works fine and I am on the 4th trailer with it. The only problem is it was made before the standard 5/8 11 spindle. I have had it for a long time.
02-22-2012, 10:31 AM
#23
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Dr airstream must be responsible for all those milk tankers I mistake for AS's on the Interstates .... Great Vid!!
02-22-2012, 10:36 AM
#24
1982 34' Limited
Brunswick
, Georgia
I have used the HF on my 34' with no problems either. It still works fine. and like I mentioned earlier it is $49. The new HF polishers have the standard 5/8 11 spindle.
I am finishing the last step with Nuvite S and a Cyclo.
Wheelerimage:
Check out this link from VTS. I polished this way with good success: Polishing Advice
the wool pads available from VTS fit both the DeWalt and HF Polishers and work very well.
Also here from Nuvite:
Nuvite Home Pg
Good Luck!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
02-23-2012, 08:05 AM
#25
Registered User
2019 27' Globetrotter
1957 16' Bubble
1957 22' Flying Cloud
Hillsboro
, Oregon
@Clifford...I was waiting for this . "A little experience" is correct but I'm DeWalt all the way, with the 3m pads you referenced. Now....if only I could figure out how to bedazzle my DeWalt (yup...have my own) and become a Nuvite dealer all would be good!!
@Goranson...bummed you bought a Cyclo...we would have let you borrow ours.
02-23-2012, 08:19 AM
#26
1993 34' Excella
Estancia
, New Mexico
I have a bunch of HF tools. My grinder polisher lasted longer than I thought it would, but did eventually burn up. Got my whole stream polished though, except for the final step which I have a Cyclo. For the $35 or so I paid it was worth it. I look at them as throw away tools. The car buffer did not last at all. You pays your money and takes your chances.
02-23-2012, 12:42 PM
#27
1966 26' Overlander
Woodstock
, Georgia
The guy in that video did a class at one of our N Georgia Rallys. Great to see it getting done in person.
02-23-2012, 12:54 PM
#28
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
The guy in this demonstration used the HF polisher...followed with a Cyclo Polisher.
You're right Alan, seeing a live demonstration is always helpful. FWIW, "the guy" in this demo is Mr.InsideOut
Shari
02-23-2012, 02:15 PM
#29
1982 34' Limited
Brunswick
, Georgia
Shari
great video! makes me want to go and polish some more!
I see why your avatar is so shiny!
1982 34' Limited
WBCCI #3321
TAC #GA-24
02-23-2012, 02:22 PM
#30
Registered User
1957 16' Bubble
Hillsboro
, Oregon
I LOVE my shiny Airstream!!
02-24-2012, 04:48 AM
#31
SW
, Pennsylvania
I just got done with the rough cut using a black and Decker 7" buffer that I bought from Amazon. It worked really well. Tons of power and the vari speed is nice. Cost is about $55
02-24-2012, 05:20 AM
#32
Lin
, Ne
Just as you do when you buy a china st tire.
02-24-2012, 08:28 AM
#33
1955 22' Safari
Butte
, Montana
OK. So maybe I changed my mind. I might give Harbor freight a try. Maybe I will take worldinchoas hint and buy the extended warranty. Still way cheaper. I am always looking for bang for my buck. I already bought my Cyclo polisher used off ebay. Thanks for the input everyone!
08-31-2012, 01:36 AM
#34
Long Beach
So... revisiting this thread while polishing my next project. Finally bought the Dewalt, my Northern Tool became intermittent. When I first used my new Dewalt I noticed a smoother start and stop. I also like the rpm indicator on the variable speed control. Takes the guess work out of just the single digit numbers.
Skip the HF buffer, buy a Dewalt. period.
1947 Curtis Wright
1958 Traveler 18'
08-31-2012, 04:30 AM
#35
1982 34' Limited
Brunswick
, Georgia
I dont disagree; dewalt makes fantastic, high quality products. ( btw, the single digits on the hf digital display indicate rpm x 1000).
However, the dewalt is not $40 and both get the job done. If I had more than 1AS i would probably make the investment.
How is the polishing coming out?
1982 34' Limited
WBCCI #3321
TAC #GA-24
08-31-2012, 07:27 AM
#36
1962 24' Tradewind
Tucson
I have burned the motor in my DeWalt out twice on the same trailer in less than 6 months!
08-31-2012, 08:27 AM
#37
1968 28' Ambassador
Cedaredge
I bought 2 HF polishers. Both Variable speed. One digital read out one not. Both have worked great. For the AS and other projects
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
09-01-2012, 12:14 AM
#38
Long Beach
Not knocking the HF when it works. I burned my first HF out. Then I thought I would step up a little and bought the Northern Tool, just recently became intermittent. If I had bought the Dewalt the first time out, maybe I would have saved money on the other two buffers. It sucks when your in the middle of a polishing project then have to wait for the new buffer.
1947 Curtis Wright
1958 Traveler 18'
09-01-2012, 04:42 AM
#39
1982 34' Limited
Brunswick
, Georgia
I hear ya, its frustrating dealing with parts or tools problems in the middle of a project.
I bought two hf polishers assumimg they were going to burn up. I used the money i saved and got the cyclo. Now THAT is a great polisher. I use it on the truck too
1982 34' Limited
WBCCI #3321
TAC #GA-24
09-02-2012, 04:38 PM
#40
Stonewall
, Manitoba
Where to find pads?
Howdy Airstreamers, I'm about to attempt a first time strip n' polish (for both of us) and I need to know where to buy the polishing pads and the gray and pink bars to use with an angle grinder like in the video above. I live on the Canadian prairie and would prefer a local source, but I don't know exactly what to ask for. So what's the preferred nomenclature for them there wheelie buffie things?
Any good source online might also be useful, thanks.
Btw thanks for the video, it's very helpful.
