Old 09-03-2012, 01:30 AM   #43
cuyeda's Avatar
Long Beach , California
@roadking67
I don't know the dealer networks in Canada, but check this website to help you with a suggested product list. Also read the basic process outline for the proper steps to take for a polishing job.
Jestco Products Buffing Supply - Airstream Polishing Kit (for lengths over 24 foot) #799L (Powered by CubeCart)
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 09-03-2012, 05:33 AM   #44
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Before you start with an angle grinder, make sure you double check the rpm requirements.
I used the pads flat against the AS and the recommended rpms were no more than 3200 or so. The "wheel/edge" method may be different.
I believe my dewalt angle grinder is in the 8000 rpm range. A little too fast
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 09-03-2012, 07:00 AM   #45
toastie's Avatar
1955 22' Safari
Great Lake State , .
To keep that mirror look you will need to stay at it ever year, and the Harbor Frieght just won't handle it. I went with the Dewalt and very happy with it, handles the pads without any problems..........toastie
toastie is offline   Reply With Quote
Old 09-07-2012, 09:47 PM   #46
I am a fan of the HF Buffer...
If I had the $200 for a better one I would have bought it... but would it be a wise investment??
I seem to remember I got paid about $30 with the 20% off coupon.
The 2 year warrantee was another $20 I think.
You get some fresh bushes with each one... Not used them yet...
The first one died... or I can I admit that I killed it!
It did the whole really really badly oxidized rear cap, most of the front, and about half of one side of my 34.5' MH.
I have used it with a wool buffing pad AND with an 10" edge wheel... and both have been seriously leaned on!
Also, it fell off the roof of the MH at least once and a few more times from lower heights.
Also I was running it on my MH genset, and a portable generator, which I am sure is less than healthy current...
When you return them they give you a free buffer, but you pay for the warrantee on the new one... $20.
The 2nd HF buffer seems to be hanging in there so far, and if you have seen my polishing thread, you know both of them have been.."Ridden hard and put away wet!"
Not including my Cyclo, which I have barely used for this basic polish, I have invested about $70 in machinary so far, and the results are satisfying me...
Old 09-07-2012, 10:28 PM   #47
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Same story here. Bought the first one, buffed out my entire interior...burned out and warranty covered number two which I will be using on the exterior. $50 bucks well spent.
Phrunes is offline   Reply With Quote
Old 09-29-2012, 11:40 AM   #48
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
I found a cyclo on Craigslist for $120. Like it. Prior to that used a variable speed from Harbor Freight.
I buy from HF if I am only going to use a tool once or twice. My brother always said if your life or livelihood depends on it..... get a dewalt.
Jim Lee is offline   Reply With Quote
Old 01-23-2013, 12:08 PM   #49
2006 34' Classic
Okc , Oklahoma
Which one of harbor freight tools for polishing is the equivalent to dewalt or cyclo?
Sooners67 is offline   Reply With Quote
Old 01-23-2013, 12:15 PM   #50
This is the Compounding Polisher I am using for first cuts...
7" Electronic Polisher
And this is the Dual Action I am using...
6" Variable Speed Dual Action Polisher
I was wrong about the warrantee... it was $10, not $20.
Buy a Hot Rod Magazine or the like and you will see a 20% off coupon for whatever you buy... and this montth the DA unit is $49.99, minus another 20% which pays for the warrantee!
Thats just the way I am rolling until I can afford better!
If anyone needs wool pads... pm me!
Old 01-23-2013, 12:20 PM   #51
2006 34' Classic
Okc , Oklahoma
Which HF polishing tool did u purchase?
Did u use it o strip off the clear coat?
I am debating whether to buy a dewalt or harbor freight
I have a 34' classic I want to shine like a star.
Marshall
Old 01-23-2013, 12:41 PM   #52
Plenty of info in the sticky thread in this forum...
The tools I bought are in the links in my previous post, but you need to strip off the clearcoat first with a chemical stipper.
Old 01-23-2013, 12:49 PM   #53
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Marshall
buy the HF polisher, use the money you save to buy the cyclo.
at $40, I bought 2 just in case one died. Both still work fine.
I haven't found a better tool to remove the swirls on the final pass of Nuvite S than the Cyclo. I tried a standard DA polisher and it took more effort with marginal results; cyclo worked like a champ!
with the 34' you will appreciate the "less effort" part
I used a plastic scraper (be careful not to scratch) to get the clear coat/ stripper off, then soapy water. Small sections at a time.
in general I have found there aren't many if any shortcuts to the process. dont skimp on the wool pads/ or airwheels (depending on which method you are using), they make all of the difference. Especially when you have 34' to work with.
BTW, you are required to post pics when you start the process.... it is in the rules!
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 01-23-2013, 12:54 PM   #54
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Keyair
your MH looks Awesome polished up!!!! Makes me want one!
C
1982 34' Limited
WBCCI #3321
TAC #GA-24
Land Yacht Harbor Park rtaylor537 Winter Living 21 02-25-2012 06:25 PM
Bar Harbor or Bust! ZoominC6 On The Road... 6 07-28-2011 06:56 AM
Caravan to Land Yacht Harbor / Crab Feed monah WBCCI Rallies & Events 2 02-10-2011 11:49 PM
Bass Harbor Campground.. kidsgone On The Road... 2 01-22-2011 06:23 PM
freight carrier Smokeydawg Our Community 1 12-23-2010 06:51 AM
