Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 04-12-2010, 02:32 PM   #1
Boulder , Colorado
Hand wash VS power "car wash"
Hello.
I have a newer Safari (2006). Obviously wash & wax by hand is preferable...but I have to pay someone $250 to do my 30 footer. They're experienced and will go "with the grain"----which is all the manual says about washing the exterior.
There is a "Truck & RV Wash" by my house for $40! Guy says they use wax that Boeing uses on their aluminum aircraft and that my Airstream should be fine. It's obviously some sort of pull-through power wash application.
Any thoughts/experience? (Obviously, I don't want to trash my rig for $200...but I'm thinking a power was shouldn't hurt an 2006.)
Thx!
TommyL is offline   Reply With Quote
Old 04-12-2010, 02:45 PM   #2
2000 30' Excella
Kirkwood , Pennsylvania
Go for the car wash and buy a product called Envy (Waterless wax) and follow the directions and do it yourself......It is the best product I have ever used and is the easiest to use. You can buy it from the Airstream Store I polished my 2004 30' Classic and also my Ford F-350 Dually and I ordered (2) more bottles from Airstream. I washed my AS first with Blue Coral car wash/wax first just to remove any grit.... You can do the same and save yourself $200.00
Steve (Solar Stream) Loden
WBCCI # 3601
TAC # Pa. 11
Solar Stream is offline   Reply With Quote
Old 04-12-2010, 02:50 PM   #3
2010 27' FB Classic
N/A , Texas
Well, here are my thoughts on that:
The power wash could loosen any questionable caulking and wash it off then you will have a leak before long. Those guys will never notice anything missing. Not sure if your hand wash guys will either but at least there is a better chance of them spotting something especially if you ask them to look at the seams and seals.
I try to hand wash my own trailer so I can see it close up and check the caulk and seals as I go. I have, in the past found lots of stuff that way, and corrected it before it became a problem.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
Bluto is offline   Reply With Quote
West Virginia Declares Official State "Car" fireflyinva Airstream "In the News" 9 09-19-2010 08:43 AM
Any info about 'car low voltage cutout' on this schematic advent Batteries, Univolts, Converters & Inverters 8 05-07-2010 02:59 PM
I Bow Before You (with plate in hand) Her-Highness Shari aka "Rib Queen" MileHigh Off Topic Forum 1 10-16-2004 12:47 PM
coin car wash wax david h Our Community 1 01-13-2003 08:27 AM
