Old 07-10-2009, 11:34 AM   #1
1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
half polish, dull, or matte, polish techniques ?
want to polish my 54 FC but not to a mirror. actually want it to look clean and bright but not real shiney or mirror? ive polished a couple airstreams before with nuvite to a mirror (or close) shine so i kinda know what i'm doing. i looking for both product and technique suggestions . thanks
greenrig is offline   Reply With Quote
Old 07-10-2009, 11:47 AM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Mothers is a good one for great cleaning but will not try to give you the mirror shine....
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-10-2009, 09:41 PM   #3
1959 18' "Footer"
redhawker, did you do your overlander with mothers? what would i apply it with i wonder? elbow grease?
Old 07-10-2009, 10:24 PM   #4
1959 18' "Footer"
any feedback on the truck box polish, diamond brite i believe.?
Old 07-11-2009, 05:49 AM   #5
2008 16' Safari
Destrehan , Louisiana
One of the goals of the high polish to to remove all of the tiny scratches and restore the finish to a "like new" condition. There is no law that says you have to take the polishing that far. The polishing compounds come in different grades. Just stop at the level of polish that you feal is good. Or you can polish all the way out and just wait. The surface will slowly dull on it's own.
dlb435 is offline   Reply With Quote
Old 07-11-2009, 08:12 AM   #6
BarryIowa's Avatar
Polk City , Iowa
I have used Diamond Brite and Nuvite and with either of these polishes I think it would be difficult to get an even polish short of the mirror finish. When I used either polish, my 55 Flying Cloud looks like a mirror from 10 feet. Only when you get closer do you see the swurls or tiny scratches. It seems to go pretty quickly from dull to mirror when using a compounder. I'm not sure it there are other products out there that could help you get to the luster you are after.
BarryIowa is offline   Reply With Quote
Old 07-11-2009, 08:22 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
You can have it blasted with walnut shells or baking soda...this will give it an overall "clean" semi-matt, not shiny finish.
Shari
Old 07-11-2009, 09:05 AM   #8
Lothlorian's Avatar
Loganville , Georgia
Very interesting comments. My finish on my sides front and back look fine. It is the top that does not look to hot. I like the way mine looks but I would like to get my top to look like my sides. I want it to be uniform. I
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 07-11-2009, 12:07 PM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
You could just strip it...once the milky white of failed clearcoat is removed, you may have a more even looking finish. The clearcoat on the top is the usually the first to go...the sides last a bit longer - but if yours is just starting to go, and the areas where the clearcoat has already failed hasn't oxidized to much, it may look good all over once stripped. A friend was able to do this with his '69 and it looked MUCH better after stripping - since then it has just oxidized all over pretty evenly - looks better than failing, patchy clearcoat.
Shari
Old 07-11-2009, 10:11 PM   #10
1959 18' "Footer"
baking soda blast! yes! this would be a great compliment to an acid bath to make sure that acid stops in its tracks. i actually know nothing about either one. but i liked the baking soda blast idea. is this equipment rentable. anyone done this? sounds really cool..and easy. ive got my nuvite ordered already, i know what i have ahead of me and i'm not looking forward. i'm tired of the 'black' and even though i wear as much protection as possible, i'm still concerned with health effects from polishing. that stuff is narly.
Nevr-Dull polish? Deluxe21 Cleaning, Stripping & Polishing 8 06-30-2010 10:28 PM
to polish or not to polish that is the question Frank's Trailer Works Cleaning, Stripping & Polishing 17 08-26-2007 11:15 AM
To Polish or not to Polish, that is the Question? mello mike Cleaning, Stripping & Polishing 14 03-22-2005 11:28 AM
Never dull Polish 71excella500 Cleaning, Stripping & Polishing 1 12-22-2003 07:17 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
