Old 07-11-2010, 03:08 AM   #1
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
Gords Aluminum Polish - test 1
(photos in next post - still learning the ropes)
I gave Gord's Aluminum Polish a test run on some interior aluminum before embarking on the exterior.
This stuff is so easy to work with. It's main purpose in life seems to be to consume aluminum oxide. It turns it black and oily (like my hand in the photo) and then it just wipes off. The scratches were already on the railings when I found them.
I used a #0000 steel wool pad to scrub the thin, oily, stearic-acid based polish onto the aluminum. It didn't take much. I used a red shop rag for removal. I will substitute an adjustable low-rpm buffer for the steel wool when I do the exterior.
All six rails took me just over an hour and a half - photo documentation and coffee break included. Better living through chemistry.
SpaceEgg is offline   Reply With Quote
Old 07-11-2010, 03:15 AM   #2
SpaceEgg's Avatar
1959 24' Tradewind
part deux - photos
Photos (correctly attached). Top two are Brasso, bottom ones are Gords.
These are the railing tracks that hold the sliding doors for the overhead compartments to a Tradewind. Mine are very old. The top two are what Brasso was able to accomplish.
Then I used Gord's Aluminum Polish to see what it could do. Bottom photos are after the first "cut" (about 5 min). There's actually no grit to the polish, it's thinner than olive oil.
ID:	106590   Click image for larger version
ID:	106592   Click image for larger version
Old 07-11-2010, 03:20 AM   #3
SpaceEgg's Avatar
1959 24' Tradewind
part trois
My proficiency improved by the third rail (right to left). Ignore the dirty hand and check out the difference in reflection between the pre- and post-Gords' Polish.
The rail on the right shows the type of residual gunk that was removed from the rail on the left (bottom image).
It helps to have GoJo or FastOrange around to clean your hands!
ID:	106594   Click image for larger version
Old 07-11-2010, 05:12 AM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Looks good. Never heard of Gords. Where do you get it? Let us know how it works on the exterior. It would be interesting to see the results when you hit it with a buffer.
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 07-11-2010, 05:16 AM   #5
Baltimore , Maryland
I think you would find that diamond brite would give you the same result. There is a big difference between chemical removing of oxide and polishing. Steel wool and aluminum are also a very bad combination. Instead of steel wool try wet dry aluminum oxide sand paper. Just a suggestion.
Old 07-11-2010, 06:59 AM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Very interesting. Thanks for sharing.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-11-2010, 07:10 AM   #7
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
Thanks keep us updated!
NashBuff is offline   Reply With Quote
Old 07-11-2010, 08:04 AM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I would agree with the steel wool except that #0000 is pretty dam fine and wouldn't scratch the aluminum. My farther, and Antique restorer used it to strip and finish 500+ year old furniture.
This stuff my be the ticket. I about to start striping mine in about 3 weeks. I'm not looking to get all the scratches out I just want it to shine and not have half the clear coat on and half off. And I don't want to have to do the whole trailer 3 times.
Keep us updated.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-11-2010, 08:13 AM   #9
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Idid see the promo video on Gord's site and it looks good.I think I would look at a body shop supply for an aluminum wool instead of the steel.Since I am trying all of these methods on my first polish job Gord's will be next.Using the bar method is still time consuming,but tried a pre wipe with Gojo and that worked pretty well.
Have you used Gord's on an area with filiform?I would like to see how it works on such an area as this seems to be the most challenging area for me to deal with on the skin.
bwaysteve is offline   Reply With Quote
Old 07-11-2010, 08:26 AM   #10
_
folks love mystery products that do magic.
http://www.airforums.com/forums/f441...ish-35801.html
http://www.airforums.com/forums/f441...-up-23222.html
http://www.airforums.com/forums/f161...ams-14779.html
http://www.airforums.com/forums/f441...xas-66682.html
even the VENDOR posted once about his secret sauce...
http://www.airforums.com/forums/f206...you-11776.html
the old s'shine threads were also a fun place to waste money/time and debates...
http://www.airforums.com/forums/f441...ish-16051.html
http://www.airforums.com/forums/f441...rked-6541.html
CLEANING isn't POLISHING
regardless of the name on the label.
at LEAST they've got the msds on line...
http://www.gordsaluminumpolish.com/s...lMSDSGP100.pdf
this stuff is basically mineral spirits (stoddards solvent) with a dash of acid and alum/chrome oxide.
so at the very least WEAR GLOVES, geez whiz.
__________
the problem with steel wool isn't 'abrasiveness' but rather the STEEL part.
microfine impregnation of steel/iron into aluminum is not a good thing.
especially so on the exterior but anywhere water exposure is possible.
__________
one could use lighter fluid, mixed with flour and achieve the same results with LESS harm.
in fact WATER alone (with a dash of bar keepers friend) or
mineral spirits and the steel wool may DO exactly the same thing...
or ANY of the petroleum solvent/acid/oxide combinations available....
cleaning an aluminum tank by hand is SO not like polishing and compounding yards and yards of aluminum.
also keep in mind the SOLVENT and it's effect on the sealants, gaskets and rivet heads that HOLD the old streams 2gether ...
there are 100s of threads here from folks wasting money and time trying 'stuff' to polish...
and MOST of them eventually drift to the proven, tested, predictable products and a cyclo or da gizmo...
for the old alclad streams...
cheers
2air'
Old 07-11-2010, 10:18 AM   #11
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
Ask an ole Aircraft Guy ,,, steel wool and aluminum is a no no,,,,
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 07-11-2010, 11:42 AM   #12
Maniacal Engineer
barts's Avatar
Menlo Park , California
Scotch-Brite pads are available in a wide variety of grades, and leave no metallic residues behind. Alternatively, stainless steel wool is also available, but is definitely more costly.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-11-2010, 01:57 PM   #13
lpatkins's Avatar
1976 23' Safari
Chauvin , Alberta
Tried this stuff on my trailer this spring, worked well, as long as you not trying to buff out the scratches. Do small areas and keep it out of the direct sunlight, seems to provide a good finish afterwards. Its been raining for the last 3 months up here and the water is still beading off. I will post some pictures later. I think its a good alternative for those of us that don't have alot time. Good luck.
Larry Atkins
Chauvin AB
lpatkins is offline   Reply With Quote
Old 07-15-2010, 01:49 PM   #14
SpaceEgg's Avatar
1959 24' Tradewind
Gord's genie grants you 3 wishes!
cheers
2air'
Incorrect. What you just described is a crummy version of homemade napalm.
Viewpoints like this are what led me to believe this product didn't get a fair turn on these forums. I found all the referenced threads above, I spoke directly with the vendor, I thoroughly read his patent online, and decided to give it a shot. Simply sharing my experience with a new product.
For the speed, cost, and effectiveness, I think this product may be a superior overall package. What appeals to me is the staying power of the sealant, as referenced by lpatkins (photos?) and evidenced by the areas on my Tradewind that I've done by hand. I think it may far outlast the results from Nuvite/cyclo. Don't need another "labor of Sisyphus" in my life.
Gord's does have it's drawbacks. For instance, when applied, the product turns black before it rubs off, and if there are scratches, the black rubs into the scratches, probably until it's buffed out the old-fashioned way (photo below).
Important to remember these photos are taken with a 10.0 megapixel Macro lens from one inch away. My eyes can't even focus on something that close.
Gord's Aluminum & Chrome, Cleaner, Polish, & Sealer
I'm hoping to make time in July to take the buffer to the exterior with this product, and I'll post the results. Keep that parachute open.
Adios Earthlings.
Sharkhide Aluminum Polish,Anyone? magna1111 Cleaning, Stripping & Polishing 7 09-29-2015 09:42 AM
Gords Polish Robmk2 Cleaning, Stripping & Polishing 5 09-08-2007 09:22 PM
POLISH TEST / And the winner is? AirHeadRik Cleaning, Stripping & Polishing 27 08-26-2007 12:18 PM
Gords Polish will work for you! GordsPolish Commercial Listings 29 04-29-2005 09:34 AM
has anyone used Gords polish? 3x2x4sp389 Cleaning, Stripping & Polishing 6 04-06-2005 07:18 PM
