Old 05-15-2014, 09:19 AM   #1
Durham , North Carolina
General Question About Filiform Corrosion
I'm considering the RV lifestyle and in investigating Airstream Trailers two issues seem to set them apart from the rest. Filiform Corrosion and Frame Rust.
With regards to Filiform Corrosion, why is it that only newer Airstreams are affected by this? Is the quality of the aluminum in newer trailers at fault? Is there nothing that will prevent this completely? So Far, most of the information that I've seen revolves around treating the corrosion as it appears.
Sun Ra is offline   Reply With Quote
Old 05-15-2014, 09:44 AM   #2
Gainesville , Florida
It only affects some trailers and is only cosmetic. Frame rust only a problem on very old trailers as far as I know. Jim
Old 05-15-2014, 03:06 PM   #3
So what does one need to do with an Airstream to minimize or prevent filiform corrosion?
Old 05-15-2014, 03:32 PM   #4
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Everything you need to know is here:
Landrum is offline   Reply With Quote
Old 05-15-2014, 03:34 PM   #5
Landrum's Avatar
Sorry.....hit reply too soon. This is a very long thread about the subject. Very long. The corrosion can be treated and controlled. I would actually read the thread backwards if you simply want to know the preventative measures to take.
http://www.airforums.com/forums/f142/corrosion-problems-with-new-airstreams-31743.html
Filiform Corrosion - Live with it? mello mike Cleaning, Stripping & Polishing 2 03-26-2011 06:36 AM
Is this filiform corrosion (photo attached)? Or something else? Direwolf Buyer Guidelines 7 12-23-2010 03:32 PM
Nuclear Reactor Corrosion versus Airstream Filiform Ray Eklund Ribs, Skins & Rivets 0 06-08-2008 12:56 PM
Filiform Corrosion? Harper Ribs, Skins & Rivets 7 06-08-2008 10:45 AM
Filiform corrosion Brad Hunt Ribs, Skins & Rivets 4 11-19-2007 12:17 PM
