07-13-2010, 10:39 PM
1968 20' Globetrotter
fair oaks
Garden sprayer to apply Removall?
I don't own paint spraying equipment so I was wondering if anyone has tried to apply Removall or Hydorstrip with a garden sprayer. Im not sure what the consistency of either product is. I have some on back order and was wondering if this is a possiblity or if I need to just brush it on.
07-13-2010, 11:14 PM
Silver Mist
Riverhead
, New York
use a 4" brush, hose it off
07-14-2010, 04:56 AM
1965 22' Safari
Poland
, New York
We brushed it on and pressure washed it off. It worked great and was pretty easy .
07-14-2010, 07:34 AM
1975 31' Sovereign
Houston
What is Removeall?
What is Hydrostrip?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
07-14-2010, 07:47 AM
1965 28' Ambassador
Irving
What is
Originally Posted by Distantdrummer
What is Removeall?
What is Hydrostrip?
Removeall is a (green) non nasty stripper sold by Vintage Trailer Supply.I believe Hydrostrip is the same stuff under a different name.I never could find it and VT was out at the time so I used Aircraft Stripper(autozone)It did a great job.Use gloves,a good two stage respirator for any stripping and rubber gloves.Apply with a brush a heavy coat in one direction,let it sit for 20 mins. then take a nylon brush and make circles through it to break it up then hose off with a power handle on a garden hose.This stripper will get 95% of all of it.There will be small spots that will take a second app.I then washed the whole coach down with dishwashing soap and water with an RV brush to neutralize.
07-14-2010, 08:16 AM
1967 22' Safari
1960 Caravel
Edmonds
Over spray could be a real problem and you should probably use a respirator. I would not what that stuff in my lungs or eyes. Brushing it on will be much easier to control.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
07-14-2010, 08:18 AM
1970 27' Overlander
Espanola
, Full Timer
Hydrostrip is what I do when it gets over a hundred degrees outside!
07-14-2010, 08:40 AM
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound
remove all?
Has anyone used a stripper on a unit that not only has clear coat, but painted stripes and other areas as on my 345? Would like to strip the clear coat without screwing up the paint or vinyl strips, and what does the rinse off do to the zipdee awnings? Do they need to be removed? The aluminum seems to be higher polish under the clear coat in areas that have flacked off. Thanks in advance for the experienced info!
07-14-2010, 09:53 AM
fair oaks
Anyone use Prep 240?
Here is link to the product description. Note that it can be used on aluminum surfaces and will not affect rubber. Its water based and low VOC.
http://www.ppg.com/corporate/durapre...heet_FINAL.pdf
07-14-2010, 09:56 AM
1967 24' Tradewind
Greenville
, South Carolina
I believe you should keep it off the vinyl and paint if you are wanting to keep them.
