Old 03-20-2012, 10:34 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
follow up after polishing
I'm going to be finishing up and was wondering if the polished surface shoul be waxed or anything else.
Also what about a year from now?
'77 Sovereign Intl 31' CB
Old 03-20-2012, 11:38 AM   #2
Bob.
Only ways to protect that hard work.
1. Clearcoat the trailer.
2. Wax and wax and wax, every 6 months, to make super sure that the elements cannot harm that hard work.
Over waxing is never a problem.
Under waxing allows the elements to do their nasty work.
Old 03-20-2012, 11:57 AM   #3
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
80 hours and never again.. ~!
Down to the last level of polish,,, and trust me,, NEVER AGAIN! I have waxed cars and trucks with paste wax and to polish out an old Airstream has to be the hardest job I have ever done..
So clear coat... MMmmmm?? What flavor or such does one look for.. Just a auto type clear coat?
Somewhere I read that if one has a high grade finish on Alum,, then the clear coat will not stick and will peel off in a few years.. Then one would be right back to square one..
Love the look of a polished up 40 year old Airstream,, but My goodness..
Sodbust
Sodbust is offline   Reply With Quote
Old 03-20-2012, 12:16 PM   #4
Sodbust
Automotive clear paint is designed to be applied on top of paint, never aluminum.
Airstreams clearcoat lasts about 5 to 6 years with proper care, which is designed to stick to aluminum.
It all depends on someones wishes as to where and how they want to spend money and their own energies.
Old 03-20-2012, 01:46 PM   #5
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
That Hawaii holiday was short Andy???????????????
Did you see any Airstreams over there?
Dave
Originally Posted by Inland RV Center, In View Post
Bob.
Old 03-20-2012, 01:51 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Bob.
Just any auto wax I assume?
Old 03-20-2012, 02:36 PM   #7
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I use Meguires products on my vehicles. After reading Andy's suggestion to use wax on the polished aluminum, I called Meguires to get their take on it. They said that waxing the aluminum will offer protection to the exposed aluminum and they recommend waxing.
Good to know. Thanks for the heads up Andy!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 03-20-2012, 02:52 PM   #8
Bob.
The high grade Meguires works great.
Old 03-20-2012, 03:09 PM   #9
Dave
Dave.
Alooooooooooooooooooha
I hide from the Airstreams that are on Oahu.
Best I know there are only 3 of them.
And, nope, I am still here until this weekend.
Having a great time, as always.
Mahalo.
Old 03-20-2012, 06:07 PM   #10
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Did they recommend a particular one?
Old 03-20-2012, 06:17 PM   #11
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
They said that both the carnuba and ultimate (synthetic) will have the same result/protection on the aluminum. He said the difference its that The synthetic will last longer.
I tried my cyclo with meguires on the car and the cyclo made easy work of the process. I am determimed to get my money out of that machine!
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 03-21-2012, 07:29 AM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
There are discussions around here on wax in particular, with some decent results/comparisons made. My own experience (not trailers) is that it is worth searching out opinion. Doing it is one thing, doing it more often as a result of saving a few bucks (supplier and material cost), quite another.
Old 03-21-2012, 10:30 AM   #13
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
That was one reason I asled about the type of wax. The meguires synthetic is $22 per bottle, carnuba is $8
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 03-21-2012, 12:07 PM   #14
Considering the cost to strip the trailer, and then polishing materials, not to mention the number of hours of labor, and the messes to clean up, then the difference in cost of $14.00 per container of wax, is not worth discussing even over a bottle of water.
Give it the best you can. The rewards are huge.
Finally polishing my 34' c_lewis77 Cleaning, Stripping & Polishing 106 08-25-2012 02:34 PM
Hooking toilet back up Cassarey Plumbing - Systems & Fixtures 3 03-20-2012 08:23 AM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Need some parts for a window clean up ND10CentCan Windows & Screens 43 03-19-2012 05:35 PM
Door latch broke, after it was closed! frscott Exterior Restoration Forum 2 03-11-2012 01:34 PM
