Old 01-04-2014, 09:34 AM   #1
Grrrwolf's Avatar
1977 31' Sovereign
Overland Park , Kansas
Fleet Bright Experience
I've searched the forums and can't find one mention of Fleet Bright, an aluminum truck washing acid. I bought 5 gallons of this and it is supposed to give the nice satin finish that you see on tanker trucks. Does anyone have experience with this product? The pH is in the 2 range so I'm aware if the safety precautions required. Also, I'm guessing that a separate clear coat remover is required first. Thanks for any advice!
Grrrwolf is offline   Reply With Quote
Old 01-04-2014, 10:09 AM   #2
Grrrwolf's Avatar
1977 31' Sovereign
I should be more specific since I found an alkaline product with the same name.
http://www.detco.info/truckpro/wp-co...card_final.pdf
Old 01-04-2014, 10:15 AM   #3
Grrrwolf's Avatar
1977 31' Sovereign
Product:
Old 01-04-2014, 11:38 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
http://www.airforums.com/forums/f441...ons-17812.html
http://www.airforums.com/forums/f441...ear-45971.html
Old 01-04-2014, 12:17 PM   #5
Grrrwolf's Avatar
1977 31' Sovereign
Thanks, Overlander, that was fairly controversial I'm going to try this in the next few months and will post some before and afters...
Old 01-04-2014, 12:19 PM   #6
1993 21' Sovereign
That would be great. Some people just give a knee-jerk "NO!", while others keep an open mind. I think the most important thing is to make sure all acid is neutralized and rinsed off.
Old 01-04-2014, 02:38 PM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have used that or a similiar product with some success on a never polished trailer to cut through the initial corrosion. It seemed to make it much easier to polish.
I got a couple gallons from a place that cleaned trucks so I don't know the brand
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-04-2014, 04:19 PM   #8
Grrrwolf's Avatar
1977 31' Sovereign
Rick, was the clear coat removed at the same time? If I look close I know there is a mix of clear coat and oxidization in different areas, but I can't make out any pitting that sometimes occurs.
Thanks!
Old 01-04-2014, 04:23 PM   #9
MarkE's Avatar
1969 18' Caravel
, Iowa
I used this on my '51 Flying Cloud when I first got it. Like Rick, it cut through the years of built-up grime and left the trailer with a very clean and very dull appearance (there was no 'clear coat' to deal with.) After scrubbing with the acid I neutralized it with cold water rinse.
Then, I hand polished with MetAll. Much work but it polished up well.
I'd advise caution when using the acid. It can be real nasty to skin, eyes, etc.
MarkE
WBCCI #4568
MarkE is offline   Reply With Quote
