Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 10-21-2002, 04:47 AM   #1
acwdgw's Avatar
1970 25' Tradewind
1997 34' Limited
2013 30' Classic
Fixing a scratch on a brushed finish?
Due to an incident with a narrow gate in a Texas State Park campground, we now have a scratch down the side of our 1997 brushed finish trailer. The scratch is through the clearcoat but not too deeply into the aluminum. We would like to fix it so that we maintain the brushed finish and blends into the rest of the trailer. Any ideas or experience?
Dianna
acwdgw is offline   Reply With Quote
Old 10-21-2002, 05:11 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Walbernize?
The walbernize folks are usually very helpful with questions like this.
http://walbernize.com/
(800) 743-7770
Rog0525 is offline   Reply With Quote
Old 10-22-2002, 10:35 AM   #3
acwdgw's Avatar
1970 25' Tradewind
1997 34' Limited
2013 30' Classic
I sent an email to the Walbernize folks and they said they didn't have any good ideas.
Thanks for the suggestion.
Dianna
Old 10-22-2002, 01:27 PM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
If the scratch has not gotten contaminated with paint from the gate I would clean it with a very fine rubbing compound. If it contaminated I would use a bit stronger compound and then go to fine. In either case rub in the direction of the grain on the aluminun . Then I would get the proper can of spray clearcoat from a dealer and seal the scratch. You want to stop discoloration and more possible clearcoat damage. You may want to mask off surrounding regions prior to spraying so if it is not as "shiny" where you spray it will be less noticable.
Just my $.02 worth.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
mirror finish what next? kooblekidz Cleaning, Stripping & Polishing 10 04-13-2009 07:24 PM
Brushed aluminum? 69Ambassador Ribs, Skins & Rivets 7 10-21-2003 04:15 PM
exterior finish durability vs. model year Kirby Stone Exterior Restoration Forum 16 08-08-2003 09:34 AM
exterior finish Roland Clearcoat, Exterior Paint & Trim 2 06-24-2003 01:04 PM
Very rough finish lenny Cleaning, Stripping & Polishing 9 11-11-2002 05:42 PM
