If the scratch has not gotten contaminated with paint from the gate I would clean it with a very fine rubbing compound. If it contaminated I would use a bit stronger compound and then go to fine. In either case rub in the direction of the grain on the aluminun . Then I would get the proper can of spray clearcoat from a dealer and seal the scratch. You want to stop discoloration and more possible clearcoat damage. You may want to mask off surrounding regions prior to spraying so if it is not as "shiny" where you spray it will be less noticable.
Just my $.02 worth.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
