Old 12-27-2003, 07:45 PM   #435
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Looking GOOD
I finally got to check out the Stream after three months of being away and have to give Turtle Wax good marks. There were water spots and water tracks but they wiped off with no problem. It needs a bath real bad but will wait for spring when I do some more polishing. Also I replaced the vent gaskets and checked the wheels and brakes, found the magnets are worn to the screws so they will be replaced when I install the new axles, bearings and other stuff look good. I hope to take before and after pictures of the axle replacement and post on another thread.
Sure makes me want to hook up and go somewhere, "anywhere" just so I can take the Stream with me but alas I will have to head back to OK and be satisfied with dreaming of camping this coming spring.
THINK SPRING !!!!!!!!
Garry
Old 12-28-2003, 04:35 PM   #436
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I too used the blue masking tape, when I Vulkem sealed above my motorhome windows, and around the door. It worked well for me.
Also in another thread we mentioned using "Liquid Glass" sealant/polish as a final coat. I put mine on in the summer, and it is still looking quite shiny over the clear coat, after month out in the weather. I do have a camopy over the top, but the rest has been exposed for four months or so, and still shiny. A quick rinse off and the AS looks great. It was 17 bucks for the can at Pep Boys, but the one can did my 28 footer with 1/4 can left to spare.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-30-2003, 07:28 AM   #437
Wolf's Avatar
1975 27' Overlander
Thumbs up To 53 flying cloud
I am highly impressed with your work.
Could you answer a couple of questions for me.
1. what is this cyclo you speak of.
2. what are the products that helped you.
3. where did you get them.
4. what is the cost of the products.
I am in Canada and as yet have not found anything that is for aluminum.I can't beleive the differants you have made on your unit.
Thanks. Wolf
Wolf is offline   Reply With Quote
Old 12-30-2003, 08:50 AM   #438
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Talking Thanks`
Wolf.. perfectpolish
  • Quote:
    It's a very well made and durable polisher
    All 4 grades of Nuvite, plus..you need to really read thru the thread to pick up the many excellent tips from all of the other guys on here that polished their units as well..
    Check out the link above..
    That depends on what all you want. In my case..I order multi of accessories such as bonnets, polishing compounds, etc.
    Again, for pricing, it's best to call "Tom" at perfectpolish and, get a quote from him..
Good luck to you and, looking forward to your reports on the project once you get it underway`!!
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-30-2003, 08:55 AM   #439
Wolf's Avatar
1975 27' Overlander
Thanks!
Much appreciated, and I will keep updating with my progress.
Must also get a digital camera for uploading some pics, unfortunately I didn't get any "before" shots of the interior, now that was quite a sight!
Wolf
Old 01-01-2004, 06:54 PM   #440
1984 29' Sovereign
Savannah , Missouri
Looking for...
Wolf,
Whenever you can post some pictures..I know we're all looking forward to that`!!
Again, good luck on your project..
It takes a small amount of courage to get something like that underway~!
Like one of the guy mention before.."Once you start..there's no turning back.."
The end results will be well worth it~!!
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-03-2004, 12:18 AM   #441
1984 29' Sovereign
Savannah , Missouri
Unhappy The latest...
Last weekend, I finally made a trip back to our unit..A time lap of 4 months had passed since I saw it last...I was real curious as to how the polishing job held up. The word on the wax is..Not that good. From a distance the unit looks great~! But, up close, you can see the water marks, etc..Looks like I'll need to re-polish it once more..Granted now, this'll be a low level polishing effort.
I'll need to do some further research as to what to use in the future..Anyone out there had any long term results to report on?
BTW, THINK SPRING~!~GET THE CYCLO OUT~!
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-03-2004, 06:37 AM   #442
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I've been polishing with the compounder and Nuvite for the last few weekends. Just have a small area around the door and then from the top of the windows up. Seems my pads have worn out because they don't work like they used to. I'll get some new ones before I pick it up again this weekend.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-03-2004, 09:27 AM   #443
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
If 5 years is a long time, I can tell you my experience - of course have to consider that I live in a dry climate and store my trailer inside.
Those water streaks you are seeing are not big deal - when you re-wax they should come right off.
I use Rollite sealer, so I don't know about anything else - I've used it for the 5 years and I think it works great.
What I do is each spring I re-seal with the sealer, each fall I do a once over with Nuvite S and re-seal - keeps it looking good.
Punch my photos and you can see what it looks like.
Ken
Ken J is offline   Reply With Quote
Old 03-04-2004, 01:30 PM   #444
1984 29' Sovereign
Savannah , Missouri
Thumbs up I believe that..
flyfshr and KenJ.
Since we only had but a few days to be there..I didn't even try to wipe it..I have every reason to believe it will clean up just fine..I like your pictures and, the sound of your annual treatment..
flyfshr
One thing to remember, not all pads are equal..I bought a few extras last fall(to have on hand while the others were drying out) and, to be honest with you...It was a huge waste of money
Maybe, I'll save them for waxing the car finis?...lol
(wished we could get this thread to "stick" since Spring Polishing Time will be upon us shortly)
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-05-2004, 07:01 AM   #445
64GT's Avatar
1964 19' Globetrotter
Glenside , Pennsylvania
Dumb question, maybe. I waxed in the fall to protect the polishing I had been doing. Once the warm weather hits - how do I remove the wax to continue polishing? Will it polish off, I wonder?
64GT is offline   Reply With Quote
Old 03-05-2004, 08:31 AM   #446
Ken J's Avatar
Durango , Colorado
Images: 14
I would just keep polishing - at least thats what I do......
Ken
Old 03-07-2004, 12:29 PM   #447
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here's a couple shots of my efforts for the last few weekends. Still have the top to do and then need the Cyclo to remove the swirl marks.
FF
PS: going for page 10
Old 03-07-2004, 12:30 PM   #448
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
and another.
Finally posted photos... 85MH325 Our Community 28 04-09-2004 07:15 AM
Just started Compound Polishing. What are these black spots? TBKP's Overlander Cleaning, Stripping & Polishing 5 04-03-2003 12:34 PM
Finally an Airstreamer Paul Mayeux Our Community 10 01-27-2003 03:00 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
I finally got it home.... Chuck On The Road... 15 07-03-2002 11:11 AM
