Old 11-18-2003, 11:24 PM   #393
I havent tried to polish my Airstream Yet but Im sure I will eventualy. However I have quite extensive knowledge in polishing aluminum and steel and stainless and brass. When you sand, grind or polish aluminum you remove the layer of oxydation. This layer is basicly 1 atom thick. it is the layer that is formed emediatly after the underlying atoms are exposed. Aluminum oxide is the same material that Rubys are made from or the grit on aluminum oxide sand paper. It is basicaly a very tough hard substance. By the time it gets dull enough to need polishing it is many atoms thick. If for instance you try to just polish off the hard suface, the polishing wheel will cut through here and there and make a very rough and wavey surface. so you have to cut the hard oxydation of with something as hard or harder than it is, AND something that is on a hard substrate so as to keep the surface smooth over a large area. Wet sanding with a block will do that job. Componding will do that job. I personaly think that wet sanding with a medium hard back up will do the job faster than the compounding , but I havent done this exact job yet. Then you have the low spots caused by rivits and small dents. thes would probably be removed better by compounding. so I will be prepaired to use every available way of cutting and polishing the oxydation off with much forthought. Mac
McMullen is offline   Reply With Quote
Old 11-19-2003, 06:03 AM   #394
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Cool Just got back
Safari Tim
I see while I was away on a trip.(down to Va Beach)
Hmmm..
Thanks for your reply..I could not have said it better.
I do see that there's several points mention by austreampete, that needs clarification.
But, first..I have to run my Burb to the garage..exhaust manifold needs to be looked at..
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-19-2003, 10:09 AM   #395
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Clear Coat
Since we are getting comments from folks that "haven't been there" I thought I would add what seems to be missing from their comments.
The first step is to remove "all" the clear coat and this will impact the resulting effort required to polish your A/S. An area that may seem ok with no clear coat can have some risidual clear coat that will not compound out, can be sanded but you end up over sanding into areas you shouldn't have had to sand and cost a lot of extra time. Tim also ran into some other problems with tiny spots that wouldn't polish into a good shine with out a LOT of extra work. Everone doing the polishing has run into something unique that required experiminting to resolve. If you read thru this thread you will get some ideas of how we dealt with these problems and sharing our ideas to others that are thinking about undertaking the polishing effort.
The first step is very important in the over all effort and I believe there are as many options on removing clear caot as there is to polishing.
However; I don't think an Airmark is a reasonable solution to the DIY since you could have the polishing done by a profesional for the cost of the Airmark equipment.
Garry
Old 11-19-2003, 12:14 PM   #396
austreampete's Avatar
melbourne
Garry-
Good day,
I appreciate what you say, and you're right about the diferences- its been explained that everyones caravan is from a different area, has had different exposures etc.
You have a very new caravan- considering that pre '64 had no clear, and many others as well. I've been looking at Spartan Manors, which have a fantastic construction, far superior to an Airstream, and also have no clear.
I've also never seen clear on any aircraft- I'm not saying its not possible, but I've never seen it, and because of the maintenance it requires- as you've shown.
It does however appear to preserve the skin, to an extent, and I assume that your job was easier than someone polishing a skin that was neglected and from 1947.
I also say that a caravan owner who wishes to make life simpler, is far better served to take on the Airmark system. Its 1/3 the cost of having it polished, and you'll own it for life, and can use it yearly to touch up and re-polish much faster and easier.
Your caravan would cost roughly $3000 to have polished by a real pro- not a start up novice with a cyclo who is looking for a way to make ends meet. The results from a barrel or drum polisher are incredible, and should be less strain on the skin, due to the fact that they leave no swirling from compound.
I asked my brother who has a better memory than I, about our Dads planes and the wet sanding around rivets. He said he used a block sometimes but held the paper in his palm and allowed his fingers to spread open and flow around and into the rivets and the light compression, and said it was no problem.
Mac certainly has a good handle on the polishing aspect as well. Polishing caravans isn't something exclusive- its a very limited market. Polishing of all metals and parts is quite a large industry, and if someone has polished an air cleaner from a 1967 Triumph Tiger, its basically the same knowledge that goes into a caravans skin, just a slightly different application- and a lot less time involved.
I'd like to hear Mac's opinion of the Airmark as opposed to the cyclo as a polishing tool.
Cheers! Peter.
austreampete is offline   Reply With Quote
Old 11-19-2003, 01:22 PM   #397
Peter I havent a clue what an Airmark is unless its a brand name for some industrial tool . Please put a picture and small definition on your next Letter. Mac
Old 11-19-2003, 02:54 PM   #398
melbourne
www.airmarktools.net
Air driven barrel/drum polisher- made specifically for polishing aircraft skin.
Had you ever heard of a cyclo before?
I can say that we have drum polishers in Australia, but no cyclos that anyone has ever seen or heard about.
Read about them on the site and using your knowledge of polishing in general give us a neutral opinion. Cheers! Peter
Old 11-19-2003, 05:36 PM   #399
1984 29' Sovereign
Savannah , Missouri
Please~!
austreampete
caravan
Pete, do me a favor~
Please refer to our Airstream for what it is..an Airstream, not an caravan...Yuck~
After all, this is an American Icon~
thanks..
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 11-19-2003, 05:57 PM   #400
Gary You mentioned that my axles may need replaced from looking at the picture. Today I crawled under there and checked them and Your right they average about 5 to 7 degrees below the frame , with the trailer empty. I'm quite sure with water and food and all the other stuff They will be flat or worse. well Ive got more time than money and a well equiped machine shop so I will probably adapt some sort of booster springs. probably small air bags. If I do you'll all see the pictures next year. Mac
Old 11-19-2003, 07:16 PM   #401
garry's Avatar
1969 31' Sovereign
Axles
Hmmm..... I would sugest you look at some of the threads on axles before you make that decision. There are lots of good info on how to verify bad axles and resolving same.
Garry
Old 11-19-2003, 07:28 PM   #402
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
caravan
Peter, I'm ok with you calling your caravan anything you want, after all, it's your baby.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 11-19-2003, 07:33 PM   #403
1984 29' Sovereign
Savannah , Missouri
Thumbs up Right mate
Tin Hut
He can call "his" (if he had one) anything he wants..but, I still stand by my request..
An American icon called "Airstream"..
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 11-19-2003, 07:36 PM   #404
Tin Hut's Avatar
ciao
Glad we agree.:
Old 11-19-2003, 09:16 PM   #405
1984 29' Sovereign
Savannah , Missouri
Lightbulb Check this~
Okay...
Here's the results so far..
I made a quick trip down to Va Beach over the weekend and, the waxed job on my Airstream is still holding up~!! I was able to just lightly buff the water marks off..I'll wait till Spring, for the final results.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 11-19-2003, 11:27 PM   #406
Thanks Gary for your concern about the axles. I will definatly get informed before I do something stupid Mac
Mac
Eschew Obfuscation
Finally posted photos... 85MH325 Our Community 28 04-09-2004 07:15 AM
Just started Compound Polishing. What are these black spots? TBKP's Overlander Cleaning, Stripping & Polishing 5 04-03-2003 12:34 PM
Finally an Airstreamer Paul Mayeux Our Community 10 01-27-2003 03:00 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
I finally got it home.... Chuck On The Road... 15 07-03-2002 11:11 AM
