Old 10-26-2003, 08:18 PM   #323
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Cool If I may?
Safari Tim....
I just finis lookin at all of your most recent pictures again..(Man, I like looking at good work~!~)
I have but one comment...lmao
Don't forget to polish that "bumper"~~
okay okay ??
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 10-26-2003, 11:29 PM   #324
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Talking
garry
Please "NO TOP SHOTS"
What's the matter Garry? Getting nervous
53FlyingCloud Don't forget to polish that "bumper"~~
Argh! More work
Now that's it dark here when I get off work and durring the day still too sunny , It's gonna be harder to find time to finish it.
But finish it I will! I'll probably have to modify my work schedule or take off a few mornings. Mid morning the temp seems high enough w/o too much direct sun....
Cheers...
-Tim
theVAP - Airstream Podcast
Old 10-27-2003, 06:59 AM   #325
SafariLori's Avatar
Thanks for the advice on the polishing. I really have been just using little amounts at a time. I guess I have some of that filiform corrosion as well. I have compounded mine over and over again. I have about 40 hours in on just that little bit that I have done. I haven't bought a cyclo yet. I thought that I would compound the whole thing first, then take a cyclo over it with F7 and S.
Does anybody else HATE polishing by hand? Polishing around all those letters is a huge pain. I got out my dremel and did a little polishing with that. But it was still long and tedious work.
Garry- would a cover that didn't have straps on it, maybe something that went all the way to the ground and staked (sort of like a tent, staking it to the ground), that wouldn't be bad would it? Or should you not cover an AS for other reasons?? I always thought as soon as I got it polished, I would get a cover for it.
Lori
SafariLori is offline   Reply With Quote
Old 10-27-2003, 09:39 AM   #326
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Cover
The problem with the cover is anywhere it touches the skin it can/will scratch the aluminum If the cover dosn't touch the A/S then no problem. I plan to build a pole barn cover for mine but like everything else that is just on the "TO DO" list wilh 9,000 other things.
"Does anybody else HATE polishing by hand? "
You betcha, Just don't know any easy way. Bought a Craftsman 6" polisher on sale for $14 that did help but still wore my fingures to the bone.
Garry
Old 10-27-2003, 12:47 PM   #327
1984 29' Sovereign
Savannah , Missouri
Lightbulb I thought of that
SafariLori
I had the same problem with mine..Spend several minutes at Sears, looking at that tool...Wasn't sure if it would work..
Did you take any pictures of the results?
I did all of mine by hand and, to be honest, not that pleased with the outcome..I need to try it again..`!
ciao~
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 10-28-2003, 06:57 AM   #328
SafariLori's Avatar
I had a problem keeping the polishing wheel on the dremel. I'm too embarrassed to take any close up shots of the letters, they still need a LOT of work! I wish there was some way we could take them off and put them back on (easily)
Lori
Old 10-28-2003, 09:12 AM   #329
1984 29' Sovereign
Savannah , Missouri
Unhappy Not too sure?
SafariLori
I wondered about the exact same thing...
Just to be sure, I called the factory and, inquired about the methods used by the factory to 'fasten them'..
I was told that, they're fasten from the inside before the inner skin panels are riveted..YUCK~!
So, that took care of that..Then, later this year, in a conversation with the man known as the "Polishing Guru"; He said,
" That what he did was to very carefully to slip a thin bladed tool under them, so as not to damage the skin, removed them..Then, after he'd finis polishing the surface area, he re-attached them by drilling a hole in dead center of each letter, riveted them back in place from the outside. Then, repainted the letters over the rivet."
Sounds like it would work..
Just depends on how much detailed work you're willing to put into it..
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 10-29-2003, 10:36 PM   #330
1984 29' Sovereign
Savannah , Missouri
Lightbulb Updated report~
gvanman
As Safari Tim would say,
Hey Vern
I'm saying...
Hey gvanman~!
How about some update reports on your progress??
We have not heard nor seen from you lately..Right guys??
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 11-02-2003, 05:30 PM   #331
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Smile This one's for Garry
garry
OK, here is the top after a little work....
-Tim
Old 11-02-2003, 05:32 PM   #332
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
And another angle.
Keep in mind, this is as close an inspection that I will allow
-Tim
Old 11-02-2003, 05:38 PM   #333
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Cool 75.5 hours and counting.....
Well it went from too hot to polish to down right too cold.
Yesterday hovered at 60 degrees and today a little below that. Not to mention the time changed so its dark when I get off work.
I only have a little left in the front to compound so I am hoping for enough warm weather to get that done.
After 75 hours though, its starting to turn into a chore, just want it done Things that were not acceptable in the beginning are starting to look ok at this point
Just looking to get the compounding done, and the new running lights in place before I shut down for the winter.
This has been a Safari Tim polishing update. We now return to your regular broadcast....
-Tim
Old 11-02-2003, 05:43 PM   #334
1984 29' Sovereign
Savannah , Missouri
Thumbs up Stand by
SafariTim
In a word..Kewl~! looking very, very nice~!
Now it's garry's turn..
ciao~
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 11-02-2003, 05:46 PM   #335
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Tim
Don't know how much time you have put into trying to get rid of that WBCCI round decal - but in my experience its impossible to get off completetly. I polished that one are at least 10-15 times and got most of it off, but I think that glue has etched itself in the skin. I does pass the 10 foot test, but up close you can still see the shadow.........yuk So I've decided to live with it - my only other option was to just stick another sticker up there.
Ken J.
Ken J is offline   Reply With Quote
Old 11-02-2003, 05:58 PM   #336
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Exclamation Stickers should be outlawed...
53FlyingCloud
HEHE.... Garry, we're waiting.....
Ken Johansen
Too much time! They are terrible.
I think I will get one of these yellow smily faces and put over it
-Tim
Finally posted photos... 85MH325 Our Community 28 04-09-2004 07:15 AM
Just started Compound Polishing. What are these black spots? TBKP's Overlander Cleaning, Stripping & Polishing 5 04-03-2003 12:34 PM
Finally an Airstreamer Paul Mayeux Our Community 10 01-27-2003 03:00 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
I finally got it home.... Chuck On The Road... 15 07-03-2002 11:11 AM
