12-06-2012, 08:37 AM
1965 17' Caravel
Vinton
, Louisiana
Exterior restoration of 1965 Airstream Caravel
Well this is my first post. I have a 1965 Airstream carravel. Heavy oxidation issues. I want to restore this camper . I need some help on how to go about removing the oxidation/corrosion. All suggestion much appreciated. Would like to know what product is considered best for this task. Thank you very much
12-06-2012, 10:41 AM
1965 22' Safari
Vassar
, Michigan
Tim
TAC MI 14
Everyday is a Saturday
04-30-2013, 07:49 PM
1985 31' Excella
Birmingham
, Alabama
Originally Posted by tkasten
I'm going to give this a try. New to the airstream world.
04-30-2013, 08:51 PM
1964 17' Bambi II
Schererville
, Indiana
I am in the middle of polishing a 1964 Bambi II. It sat in the woods for 20 years and has very heavy pitting and oxidation. This is what I'm doing...it's working, but it's very labor-intensive:
1. Acid wash
2. Wet sand with 600 grit aluminum oxide sandpaper (very deep scratches I use 400 grit followed by 600 grit)
3. 3M Scotchbrite pad on a random orbit sander (the burgundy colored pad cut to size--bought at Home Depot)
4. Nuvite F9 on a Harbor Freight polisher
5. Nuvite F7 on a Harbor Freight polisher
6. Nuvite C on a Harbor Freight polisher
7. Nuvite S with a cyclo random orbit polisher
sooooo.....that's what I'm doing. I've used the wheels (and have used them a little on this project too), but I feel that the Nuvite method leaves a clearer finish. Just my OCD opinion. This is after steps 1-4
Good luck!
Becky
1964 Bambi II
1988 Avion 32S
04-30-2013, 09:01 PM
1985 31' Excella
Birmingham
, Alabama
That is exactly where I will start. One crazy question. We're did you start. Do you build scaffolding to reach the top? Total rookie but am so fired up about doing it
04-30-2013, 09:23 PM
1964 17' Bambi II
Schererville
, Indiana
If you acid wash, use a spray bottle, not a stream bottle. I use two ladders with a 2" x 12" board as a plank ( here's hoping I don't fall & break a hip!!)
Becky
1964 Bambi II
1988 Avion 32S
04-30-2013, 09:26 PM
1964 17' Bambi II
Schererville
, Indiana
I got the acid wash at NAPA
Becky
1964 Bambi II
1988 Avion 32S
04-30-2013, 09:27 PM
1964 17' Bambi II
Schererville
, Indiana
Becky
1964 Bambi II
1988 Avion 32S
04-30-2013, 09:29 PM
1967 17' Caravel
Thompsons Station
, Tennessee
I would recommend starting at chest height standing on the ground until you get the hang of it. Once you get it mastered then move on to the difficult to reach spots. I used simple scaffolding created by saw horses, strong (and wide) plank and a step ladder.
I used real scaffolding for the top, but that was at the very end after I was a pro and could lick it fast.
It will take you forever but there is nothing like seeing that shine!
My restoration photos on Picassa:
1967 Caravel
04-30-2013, 09:45 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Start on the top. If you don't you will be dragging your electric cords across polished surfaces and ruin the work done.
05-06-2013, 05:52 AM
I Bought it I Broke it...
1976 31' Sovereign
Migratory
, North America
I have what I'd consider EXTREMELY bad pitting and oxidation and I've been having great success shining it up by hand using this product Glare Knock Out that I first saw on Airstreams online store but also found a bit cheaper at Amazon. No electric buffer, but about 15-20 minutes per square foot of hand polishing.
The product mentioned is the only thing that has worked thus far for me, but at $25 / 12oz is extremely expensive. Would love to find it in a larger, cheaper quantity or a similar quality product.
My family and I have been full-timing via various modes of travel since 2008. Going on two years in our '76 Sovereign.
05-14-2013, 08:54 AM
1973 31' Sovereign
Las Vegas
, Nevada
Can you post before and after pictures? I am curious how it works.
I currently using a 3M product call Marine Restorer and Polish. It is much faster than Nuvite and works better if you ask me. It is a one step polish and only costs about $27/lb.
06-11-2013, 08:40 PM
Hazel Bambi II
1964 17' Bambi II
Tsawwassen
, British Columbia
i am in the middle of polishing a 1964 bambi ii. It sat in the woods for 20 years and has very heavy pitting and oxidation. This is what i'm doing...it's working, but it's very labor-intensive:
1. Acid wash
2. Wet sand with 600 grit aluminum oxide sandpaper (very deep scratches i use 400 grit followed by 600 grit)
3. 3m scotchbrite pad on a random orbit sander (the burgundy colored pad cut to size--bought at home depot)
4. Nuvite f9 on a harbor freight polisher
5. Nuvite f7 on a harbor freight polisher
6. Nuvite c on a harbor freight polisher
7. Nuvite s with a cyclo random orbit polisher
sooooo.....that's what i'm doing. I've used the wheels (and have used them a little on this project too), but i feel that the nuvite method leaves a clearer finish. Just my ocd opinion. This is after steps 1-4
good luck!
becky, do you recomend using the random orbital polisher or just a variable speed one? Is the cyclo necessary. I went and bout a makita random orbital, but it seems harder to use than the others. I may be wrong though.
06-11-2013, 09:16 PM
1964 17' Bambi II
Schererville
, Indiana
In step 3, I use a Skil random orbit sander (it was $20 at a Sears outlet store).
In step 7, I use the random orbit cyclo. It takes out all the swirls that the variable speed polisher leaves behind. You should try your makita random orbit polisher to see if it takes out the swirls (if you've already used it & aren't thinking of returning it). I use my cyclo every year for the yearly polish job on my trailer(s) I've pared it down to just the Bambi II, so after this year, it should be a breeze!
Becky
1964 Bambi II
1988 Avion 32S
06-12-2013, 06:45 AM
1985 31' Excella
Birmingham
, Alabama
We are still working on the interior. My first attempt at the shine will prob be in the fall. I love harbor freight. Where can I get one of those cyclo polishers. I'm so excited. I am seeing the light at the end of the tunnel. We've gutted the whole inside and put in Marine plywood Fixed about 23 hundred leaks. Fixed some wiring. Now I'm painting and then all the stuff back in. It's fun but lots of $$$. Don't give up on me
06-12-2013, 06:47 AM
1985 31' Excella
Birmingham
, Alabama
Where do you buy the nuvite stuff. Local or do you order it?
06-12-2013, 06:59 AM
Hollis
, New Hampshire
Most people get Nuvite from Perfectpolish.com. There's good info about polishing there too.
06-12-2013, 07:09 AM
1985 31' Excella
Birmingham
, Alabama
Thanks. That's where I'll look.
06-13-2013, 06:29 AM
1964 17' Bambi II
Schererville
, Indiana
You can get the cyclo polisher from here:
Cyclo Toolmakers
or you can get the cyclo and Nuvite polish from here:
Cyclo PolisherCyclo Polisher
Have fun!
Becky
1964 Bambi II
1988 Avion 32S
06-16-2013, 11:00 PM
Hazel Bambi II
1964 17' Bambi II
Tsawwassen
, British Columbia
Becky, how did you end up removing the drain pipe from he shower and toilet. I'm stuck.
Thanks ......
did you buy a special tool in the end?
Tasha
