Old 06-12-2013, 06:45 AM   #15
1985 31' Excella
Birmingham , Alabama
Originally Posted by beckybillrae View Post
In step 3, I use a Skil random orbit sander (it was $20 at a Sears outlet store).
In step 7, I use the random orbit cyclo. It takes out all the swirls that the variable speed polisher leaves behind. You should try your makita random orbit polisher to see if it takes out the swirls (if you've already used it & aren't thinking of returning it). I use my cyclo every year for the yearly polish job on my trailer(s) I've pared it down to just the Bambi II, so after this year, it should be a breeze!
We are still working on the interior. My first attempt at the shine will prob be in the fall. I love harbor freight. Where can I get one of those cyclo polishers. I'm so excited. I am seeing the light at the end of the tunnel. We've gutted the whole inside and put in Marine plywood Fixed about 23 hundred leaks. Fixed some wiring. Now I'm painting and then all the stuff back in. It's fun but lots of $$$. Don't give up on me
Tartimisi is offline   Reply With Quote
Old 06-12-2013, 06:47 AM   #16
1985 31' Excella
Originally Posted by hazelbambiII View Post
becky, do you recomend using the random orbital polisher or just a variable speed one? Is the cyclo necessary. I went and bout a makita random orbital, but it seems harder to use than the others. I may be wrong though.
Where do you buy the nuvite stuff. Local or do you order it?
Old 06-12-2013, 06:59 AM   #17
reinergirl's Avatar
Hollis , New Hampshire
Most people get Nuvite from Perfectpolish.com. There's good info about polishing there too.
reinergirl is offline   Reply With Quote
Old 06-12-2013, 07:09 AM   #18
1985 31' Excella
Thanks. That's where I'll look.
Old 06-13-2013, 06:29 AM   #19
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
You can get the cyclo polisher from here:
Cyclo Toolmakers
or you can get the cyclo and Nuvite polish from here:
Cyclo PolisherCyclo Polisher
Have fun!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-16-2013, 11:00 PM   #20
Hazel Bambi II
hazelbambiII's Avatar
1964 17' Bambi II
Tsawwassen , British Columbia
Becky, how did you end up removing the drain pipe from he shower and toilet. I'm stuck.
Thanks ......
did you buy a special tool in the end?
Tasha
hazelbambiII is offline   Reply With Quote
Old 06-17-2013, 08:27 AM   #21
Becky B.'s Avatar
1964 17' Bambi II
We didn't buy any special tools. They both turned off( after a lot of effort as I recall). We didn't reuse either one. The drain for the shower pan is one for a bar sink (from Lowes) and we used new Valterra parts for the black tank valve.
Becky
1964 Bambi II
1988 Avion 32S
Old 06-17-2013, 08:44 AM   #22
Becky B.'s Avatar
1964 17' Bambi II
They both unscrewed ( with a lot of effort as I recall) we didn't buy any special tool. We replaced the shower drain with a bar sink drain from Lowes & the valve for the toilet with Valterra parts.
Becky
1964 Bambi II
1988 Avion 32S
Old 06-17-2013, 08:34 PM   #23
Hazel Bambi II
1964 17' Bambi II
Thanks Becky,
Ill give it a try again tomorrow. Did you just use pliers from avive the drain and twist until it budged or is there a secret? I get to type to the forum each night as I try to sit with my little one as he falls asleep. If time allows afterwards I go out for an hour and work on the Bambi. Great way to gear down after a long day.
1965, caravel
Susie :: 1965 Airstream Tradewind P&A Airstream Registry Discussions 1 10-28-2011 07:01 PM
1968 Airstream Caravel mistermike Airstream Registry Discussions 0 08-19-2011 08:30 AM
1965 Airstream GLOBETROTTER JLGT5107 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1965 Airstream Caravel Vintage~17ft NO RESERVE 5 DAY ~~ eBay Watch Airstreams on eBay 0 07-12-2011 01:20 PM
1965 caravel airstream 17ft unusual options, nice eBay Watch Airstreams on eBay 4 03-24-2011 12:29 PM
