Old 11-29-2006, 07:28 PM   #1
1999 25' Safari
Rocky Mount , North Carolina
Question Exterior Refinish Help
Greetings,
I am working on a few spots that pine sap (rosin) caused on a used 25' Safari. The model year is 1999.
When the clear coat came off in the process of getting the rosin off, it created a raw aluminum spot. If I spray clear over the raw spot it does not match the finish of the trailer. So is there a product (silver/grey paint) that you spray over the aluminum before you spray the clear? Or do you compound the aluminum in some fashion and then spray the clear?
Really could use some help as the 25' Safari is in great shape other than the 2-3 bad spots caused by pine rosin.
Thanks so much for any help on this.
Steve
Steve Cherry is offline   Reply With Quote
Old 12-01-2006, 07:23 PM   #2
Originally Posted by Steve Cherry
Greetings,
Steve
Steve.
Spray a couple of coats of clear over those spots.
After the clear has aged for a few days, you can "lightly" compound the overspray areas.
That is the best that you can do.
DO NOT spray any color paint on it. That will make it look worse.
Also, DO NOT compound the bare metal. If you do you will forever change it's appearance.
You can apply a couple of good heavy coats of Walbernize on the trailer. That again, is the best that can be done.
Old 12-03-2006, 02:46 PM   #3
1999 25' Safari
Smile Exterior Refinish Help
Andy,
Thanks for your suggestions on the best fix for the problem spots. It seems that you are saying there really is not fix in terms of matching the bad spot to the rest of the exterior shell.
So far, what you have sugggested is all I have done other than compounding the over-spray.
Thanks again and Best Wishes for a Joyous Christmas Season.
Steve
Old 12-03-2006, 04:09 PM   #4
Be careful what you use to spray the bare spots. I used clear lacquer that I bought at a hardware store and sprayed a few places on my trailer. It looked great for a while but after about 2 years it turned grayish looking and looks terrible. I am considering using paint remover and then respray with the airstream stuff.
wayner1239 is offline   Reply With Quote
Old 12-03-2006, 04:52 PM   #5
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
I also have a couple of these sap spots that go down to the bare aluminum...What's the harm in leaving them exposed besides them looking unsightly? Thanks for any advice...
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
