Old 01-23-2012, 10:45 AM   #1
wondering and wandering
Wheat Ridge , Colorado
Exterior cleaning or polishing.
Hey everyone. Just looking for a tip on how to get my airstream a bit cleaned up. I'm not looking to fully restore, just get it to one tone and not look like a silver zebra.
Any thoughts?
ShawnG17 is offline   Reply With Quote
Old 01-23-2012, 10:52 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Stripping the clearcoat will get rid of the milky-white residue. If the exposed aluminum is not too badly oxidized, that may be good enough. We have known several that once stripped the disparity of the "zebra stripes" is less noticeable. You can stripe it with either an environmentally friendly stripper like CitriStrip in a couple of applications or a not-so-environmentally-nice-stripper like KleenStrip Aircraft Stripper in a single application.
Good luck!
Shari
Old 01-23-2012, 10:54 AM   #3
Any thoughts?
It looks that way because of the aged out clearcoat, which only lasts 5 to 6 years, or so.
There is nothing you can do with it, except tp strip it off, then recoat it or polish it.
If you try to polish what you have, you will remove most of it in the process.
Old 01-23-2012, 12:11 PM   #4
Thank you Shari! Good advice!
Old 01-23-2012, 12:13 PM   #5
Andy.
So would you say that if I just buy a polish and go that route I wouldn't need to strip AND polish. I could just polish?
Any recommendations on polish?
Also, can I use a rotary power buffer or will that leave bad circles?
Old 01-23-2012, 12:24 PM   #6
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Vintage Trailer Supply has a nice write up about polishing.....
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 01-23-2012, 12:31 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Just from the sounds of it....you should go with re coating it. The polish route is long, tedious and not for a beginner...unless you have lots of time to study the process...then lots of expense for the right equipment then upkeep every year. Your in Maryland...thats "dead-damn Center" of Airstream rehab/restor on the East Coast. Look up Frank here on the Forums. He can help you either way.
Old 01-23-2012, 12:42 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Deja' Vu?...my polishing input hasn't changed ~
It will leave swirls. They can be removed with a Cyclo-Polisher.
Agreed...another great write up can be found here: Perfect Polish
The bottomline is there are not any real shortcuts to acheiving an even finish that don't take lots of time or money. Your best bet for the time being would be to strip it (which you should do before polishing anyways) and see how it looks. Then decide if you want to take it any further. It will look better after just stripping it...
As far as "polishing through" the remaining clearcoat...it's probably been done, but is IMO will add a lot more work. The clearcoated areas will not begin to get polished until you burn through the clearcoat while the adjacent failed clearcoat areas will start polishing from the get-go. So you will perpetuate the splotchy look you have now. Also, if the clearcoat flakes get in the buffing pads (they will!) it will sctach the aluminum. These scratches will then have to be removed with more polishing & eventually the CycloPolisher will have to be used to get rid of the swirls.
Shari
Old 01-23-2012, 12:53 PM   #9
Soyboy's Avatar
1999 28' Excella
Images: 44
BTW, I have been stripping and polishing my 1999 Safari over the past several months, I have had great luck with Citristrip. Too cold right now to use it around here, but when the temps are 65+ or so, it works great, pretty much in one application with about a 30 min. wait before removing. Some touch up is required. I didn't want to reapply a clearcoat that would just go bad again after 5 - 10 years, plus I like shiny things, so I have been polishing mine basically using the VTS method. I looks great, much better than I thought a late model would. I actually enjoy polishing it. I have always buffed and maintained my cars, so maintaining a polished trailer won't bother me. Of course folks like P&S in Ohio can strip and recoat if you are interested.
If interested, I have posted some photos (especially in the latter pages) and info in this thread: http://www.airforums.com/forums/f441...ari-80241.html
1999 28' Safari
TAC MD-6
AIR 4534
Old 01-24-2012, 08:57 AM   #10
Thanks everyone.
Old 01-24-2012, 08:59 AM   #11
Shari
Touché.
Thanks for your help...again.
Old 04-14-2012, 10:03 AM   #12
1969 27' Overlander
Wilmington , North Carolina
cleaning the roof
what is the best product to use to spring clean the roof. it has lots of pollen and just plain ol' dirt. thanks.
123streamer is offline   Reply With Quote
Old 04-15-2012, 10:31 AM   #13
Splitrock's Avatar
Sioux Falls , South Dakota
I use a powerwasher.
Old 04-15-2012, 12:40 PM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
So, we could potentially strip off the clear coat and then just wax, perhaps, without polishing? Wonder what we would end up with? We know we don't want a high polish, looking just to spruce up, and we know our clear coat has failed.
Kay
Interior Polishing Aktundra 1961 - 1963 Bambi 13 09-22-2013 11:46 PM
Polishing in Central Texas area GeoStreamer Cleaning, Stripping & Polishing 4 09-27-2011 05:38 PM
Polishing our new Girl! bluemoontwo Cleaning, Stripping & Polishing 2 09-17-2011 07:03 AM
