Old 08-04-2008, 02:39 PM   #1
1967 20' Globetrotter
Houston , Texas
Exterior Adhesive Advice
The name plate on my Globetrotter is coming loose--the rubber one with the VIN to the right of the door, not the ones riveted to the front and back of the trailer. It seems like the heat we've had lately is causing the 40+ year old adhesive to fail. I'd like to adhere it to the skin but don't know what adhesive to use. One person at Sika told me that they did not have an adhesive that would work because the name plate is rubber (at least it appears to be some sort of rubber). Any suggestions?
tphillips is offline   Reply With Quote
Old 08-04-2008, 02:51 PM   #2
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
I am looking forward to the replies to your posting; my "A" in Airstream over the rear window is coming loose. I have tried several glues....to no avail
Interesting my Airstream is a 2002; the "A" started to come loose about 2 years ago--let's see that is 4 years as opposed to 40....
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 08-04-2008, 02:54 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
They do make an automative glue for putting trim back on cars, I wonder if this would work.....
Old 08-04-2008, 02:58 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
FYI
The old letters were attached with posts through the skin, then a fastener over the post on the inside, then white sticky gooey stuff, that is still sticky and gooey after 40 years, over the post, fastener and inside skin..
Old 08-04-2008, 03:02 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
This MIGHT be the one time you want to use some of the dreaded silicon on your Airstream. I've used the stuff to glue all sorts of things. Others will have better ideas no doubt.
Old 08-04-2008, 03:17 PM   #6
2004 25' Classic
West Chazy , New York
Earlier this year the cradle that is used to old the t-v antenna in the down position came loose during while I was washing my A/S. It was apparently secured using a glob of some kind of white mastic from the factory. I had some Sho Goo left over from a different project and applied it to the glob of mastic and lowered the antenna so as to apply a good tight hold. It worked very well. I don't have any more so I can't say what the stuff is made from, but it might work for your letter.
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 08-04-2008, 03:34 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Okay...shoe goo might work.
The white sticky stuff is a butyl based sealant and will stay gooey indefinitely as long as it is not exposed to UV rays, it is fantastic stuff for using in between metal panels. Silicone is not going to stay stuck for very long.
Aaron
WBCCI #XXXX AIR #2495
Old 08-04-2008, 04:48 PM   #8
tinhutjohn
tinhutjohn's Avatar
1974 29' Ambassador
London , Ontario
Images: 8
I've used Goop (Automotive) from Wally mart to secure some club signs etc to my door. They've been there through 25 degrees below zero to 110 above without loosening.
Sarge
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Old 08-04-2008, 05:05 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Two things come to mind AND THEY ARE NOT SILICONE!!!!!
The first is 3M auto trim adhesive and the second is 3M VHB (very high bond) tape. Before you scoff at the VHB tape, it is the ONLY adhesive that I use to fasten solar panels to a smooth roof surface when I do a solar charging system. The ape has a very high shear strength and we have never lost a panel yet with properly applied tape on the mounting feet.
OK......three things, the third being SikaFlex 221 polyurethane adhesive. This stuff is really bomb proof and is extremely difficult to remove once cured......and it comes in a nice matching grey color!
Old 08-04-2008, 05:10 PM   #10
Wayne&Sam's Avatar
Images: 21
I knew I'd get somebody going with the mention of silicone!!
Old 08-04-2008, 05:16 PM   #11
purman's Avatar
1968 28' Ambassador
Speaking of silicone, what takes that stuff off....
Use of Construction Adhesive - Any Thoughts? Gael79 Cabinets, Counter Tops & Furnishings 4 05-19-2008 04:19 AM
Vinyl Floor Adhesive kevino Floor Finishes 5 05-11-2007 07:34 AM
door gasket adhesive Al Falcon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-09-2007 10:46 AM
Exterior advice needed brenda02 Clearcoat, Exterior Paint & Trim 6 03-06-2007 09:31 AM
Exterior Polishing Advice thripplewood Cleaning, Stripping & Polishing 6 01-15-2006 07:23 AM
