I just both a 1971 27' Airstream that does not shine. I was told to use the air conditioner spray that is used on the alumnium coils in home A/C. I tried it on a piece of 1/4" aluminum and it worked good. Would this type of chemical damage the exterior aluminum of my Airstream? I would like something that works to make it shine so any advice would help. Thanks,
You can literally spend an hour or two reading the opinions and processes of shining Airstreams.
Just do a search on "polishing"
About the Aircondition coil cleaner,
I believe you have succeded in presenting the forum with a new method. I cannot wait to see the opinions on this one.
I hopes it works for you whichever method you use because them Airstreams do look good when they are shiny up
