Old 02-02-2012, 08:11 AM   #1
1975 27' Overlander
Englehart , Ontario
Ends different than middle
I hope to someday polish my 1975 Overlander. The front and rear aluminum is a different colour than the middle. If I do polish it, will this still be the case? Or will it all look the same?
Northlander is offline   Reply With Quote
Old 02-02-2012, 08:14 AM   #2
It will be close enough.
Old 02-02-2012, 08:18 AM   #3
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Its funny that you say that. I was just having that conversation last week. I am polishing my 1982 34' now. The endcaps seem to be a different color than the straight panels before polishing. Yes, they did polish out fine
ID:	150133   Click image for larger version
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 02-02-2012, 08:47 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Would the "press forming" be the reason?
Even on our Classic the finish under the clear is slightly different.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-02-2012, 09:17 AM   #5
withidl's Avatar
2002 31' Classic
Houston , Texas
Yes, the press forming stretches the clearcoat and aluminum changing the surface appearence of both, giving them a hazy look.
withidl is offline   Reply With Quote
Old 02-02-2012, 09:34 AM   #6
The press forming is done before the clearcoat is applied.
All the segments and quarter panels since 1969 are a different aluminum than the side sheets. From 1968 and older, all the segments only, are a different metal than the side sheets. metal
The aluminum that is used in the side sheets cannot be stretch formed, since it's much harder than the segment metal.
Old 02-02-2012, 09:48 AM   #7
Now I'm really kornfused Andy, I thought all panels were pre-coated by Alcoa?
I know our 63 was cleared at the factory.
PFC
"Tahawus"
RLC
John Prine
Old 02-02-2012, 09:53 AM   #8
1975 27' Overlander
Englehart , Ontario
Good to know that after polishing it will be fine. I have lots to do before I get to the polishing stage.
Carry on,
Old 02-02-2012, 09:59 AM   #9
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Carry on,
Well, even if the color is a little off, the glare from the sun will blind you anyway!
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 02-02-2012, 11:15 AM   #10
Bob.
Since the segments are all stretch formed, how can you stretch paint?
If that's possible, I would think our automotive industry would have gobbled that up years ago.
Old 02-02-2012, 12:33 PM   #11
Bob.
Airstream did indeed clearcoat the trailers and motorhomes.
It was an option in 62 and 63. Then in 1964, it was standard.
The formula was changed over time to keep up with better material, and technology.
Then, best I remember, in 1998 the metal was prefinished. The first year was terrible, then the formula was corrected.
Old 02-02-2012, 12:46 PM   #12
Question
Originally Posted by Inland RV Center, In View Post
Bob.
Andy,
Interesting....if they do coat the end panels at the factory,(before installation?), and they are aware of the corrosion concerns,(seams & rivets), there must be another reason why they wouldn't use uncoated panels and coat the entire coach in house before delivery.... as was done years ago.
Might be an easy way to avoid the filiform bad press, who knows.
PFC
"Tahawus"
RLC
John Prine
Old 02-02-2012, 01:04 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Andy,
Probably a variety of reasons starting with environmental (think Low VOC). I also suspect that a coating put on metal in a factory environment (precoating) is bound to last longer than a spray on coating.
Aaron
WBCCI #XXXX AIR #2495
Old 02-02-2012, 03:31 PM   #14
Andy,
Bob.
I am in communications with Airstream at this point, regarding your concerns and questions.
Lets see what their responce is, and I will post it for the benefit of all.
New Middle Tennessee member Liberia Member Introductions 24 12-19-2011 03:52 PM
Cobb BBQ Sale ends 11/25... Mexray Stella's Kitchen 1 11-24-2011 05:43 PM
I need this part that secures the middle awning post wacnstac Awnings 3 09-15-2011 08:24 PM
Middle of Nowhere, Doing Nothing thecatsandi Forum Rallies & Meet Ups 2 06-08-2011 06:24 PM
Middle Lane Rush On The Road... 6 05-31-2011 09:34 PM
