Old 02-12-2015, 11:05 AM   #1
1965 22' Safari
Asheville , North Carolina
Emblem Removal
Can anyone tell me how to safely remove the "Safari" emblem from the front of my '65 trailer. I have tried gently prying with a thin metal blade with no luck and fear of breaking it if I pry any harder. Cannot tell if there are metal studs on the backside holding it on or just super strong adhesive. Obviously I would like to remove, sandblast, repaint and re-apply when I am done with the polish if possible.
Thanks all!!
jjkitt is offline   Reply With Quote
Old 02-12-2015, 12:17 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My guess is there are metal studs which are glued in on the inside of the skin with mastic. You might try a heat gun.
Old 02-12-2015, 12:38 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
There are metal studs that go thru the aluminum and they have clips on the back so you aren't going to be able to pry it off. Can you remove the inside aluminum to get at the back? That would be the best way....
Failing that I suppose you could use a thin sharp metal blade to slide behind break off the posts, then reattach the emblem later with 3m tape. Might be hard to do without breaking the emblem though. If you can't get at the back I would hand polish around it and leave it alone .
reinergirl is offline   Reply With Quote
Old 02-12-2015, 02:15 PM   #4
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Removing Emblems
While the specific emblem may be held on with studs, a product called PRO-SOLV Adhesive Remover, Part # 10058-PS removes almost all glues, adhesives, and is available from Performance Specialties, Winston-Salem, NC 336-760-0225. I do not think they are on the Internet.
I have used this on almost everything without adverse consequences, and it is safe on Acrylic and Lucite finishes. Removes glue nothing else will touch.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 02-12-2015, 02:38 PM   #5
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
You may need to pull your lower interior panel. My '69 Safari has studs with bolts and the Serial number plate below it is buck riveted, not sure about your year though. Hopefully someone with your year will chime in. I would suspect you should be able to slide some tape in behind though to protect the body and paint it in place.
thesignlady is offline   Reply With Quote
Old 02-12-2015, 03:06 PM   #6
z , North Carolina
Hey JJ
While I am by no means experienced in 1960's era AS's, I would listen to reinergirl first, or anyone else with obviously more experience.
What I will say is this: A good way to confirm her statement is to get yourself some 6-10lb fishing line and carefully slide it in behind the emblem. Pulling up and down on the line will easily cut thru any adhesive that may be back there. If you are starting to get somehwere and it stops, well, its gotta be a stud.
I "de-badged" the Chevy emblems on my tailgate using this method, and it works very well, with no scratches/scuff marks from the line.
Just pull up & down in a straight manner. I wish you luck!
Kind regards,
Gavin
FishinHatteras is offline   Reply With Quote
Emblem removal (By the door) Studioman Cleaning, Stripping & Polishing 1 09-26-2014 07:47 AM
Cast Emblem and Grab Handle pitting (removal?) PA BAMBI II Clearcoat, Exterior Paint & Trim 6 05-14-2010 04:39 PM
Removing Emblem Plates Alex Clearcoat, Exterior Paint & Trim 7 07-13-2004 08:17 AM
Letter/Emblem removal Alex Clearcoat, Exterior Paint & Trim 4 07-10-2004 06:27 AM
