Old 05-03-2016, 09:45 AM   #1
2012 25' FB Flying Cloud
Parker , Colorado
Dumb Newbie Move
On our first trip with the trailer it rained ALOT. Developed a leak along the dinette window, and the first thing I tried was running a strip of duct tape along the top of the window as a stopgap measure. Later through lots of trial and error found that it was actually coming from the clearance lights.
My question is regarding removing the duct tape. I left it on too long and the sun seems to have baked it on somewhat. The tape peeled off but there is still a residue and fiber strips. Won't do that again! What would you recommend as a remover that won't harm the aluminum?
Thanks for your help, these forums have been a wealth of knowledge.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 05-03-2016, 09:48 AM   #2
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I've used mineral spirits on my 2008 and no harm to the aluminum.
Kelvin
Old 05-03-2016, 09:55 AM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Mineral spirits would be my 1st choice as well. Won't damage the clear coat and removes many adhesives.
Dennis
dennis3751 is offline   Reply With Quote
Old 05-03-2016, 10:00 AM   #4
2015 30' FB FC Bunk
Ayer , Massachusetts
Turtle Wax Bug and Tar Remover seems to work well on tape residue.
Ted S. is offline   Reply With Quote
Old 05-03-2016, 10:21 AM   #5
Sag Harbor , New York
Goof Off and Goo Be Gone maybe, but try first in hidden area. Does your aluminum have a clear coat on it?
Old 05-03-2016, 11:07 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
WD-40 works well for me. Wipe it down well to get the area covered with WD-40, then let it soak for several minutes. Let wipe off.
2019 Ford Expedition Platinum
Old 05-03-2016, 11:25 AM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Another vote for WD-40.
SeaLevel is offline   Reply With Quote
Old 05-03-2016, 11:30 AM   #8
centennialman's Avatar
2016 23' International
Centennial , Colorado
Definitely WD-40. You are safe with that.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 05-03-2016, 01:25 PM   #9
Parker , Colorado
Thumbs up
Thanks everybody for the quick responses! cheap and easy, usually not associated with an Airstream
Old 07-26-2016, 07:58 PM   #10
91 Airstream 34' Excella
GySgt Attack's Avatar
Ravenna , Michigan
Wd-40
WD-40 would be a prescription only item if it also worked well on people! The few Squeekers and Squealers that I used it on didn't fare well however. .. Bahahaha! =) Great advice though!!!
GySgt Attack is offline   Reply With Quote
Old 07-28-2016, 06:39 PM   #11
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
A little time with a heat gun will make it a lot easier for any of the above solutions to work.
brad1 is offline   Reply With Quote
Old 07-28-2016, 07:00 PM   #12
Does a bit of everything
TDHofstetter's Avatar
1963 30' Sovereign
Bradford , Vermont
The single best adhesive remover (including that from duct tape) is good ol' Ronsonol (napthalene, aka Zippo lighter fluid, the stuff in the yellow plastic bottle). A tiny bit goes a very long way. It's absolutely harmless to aluminum and practically anything else that's not oil-based, yet it dissolves adhesives better than practically anything else (acetone being one possible exception, but that stuff requires excellent ventilation, which the Ronsonol doesn't).
-- Tim --
TDHofstetter is offline   Reply With Quote
Dumb,dumb, and dumber rebel beck Electrical - Systems, Generators, Batteries & Solar 18 06-11-2023 05:55 PM
Newbie Dumb Question shebeen 1974 - 1977 Overlander 6 07-07-2011 01:51 PM
First of many dumb questions from a newbie AUTAILGATER Electrical - Systems, Generators, Batteries & Solar 11 12-09-2010 06:40 PM
Dumb Newbie Mistake #1 dmcinfo Brakes & Brake Controllers 10 08-12-2010 08:59 AM
Dumb Newbie Questions ! btr Our Community 10 11-09-2008 07:27 PM
