Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 08-11-2002, 11:25 AM   #1
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
dried adhesive removal, again
I posted this inquiry before but it may have been overlooked,
The arch-shaped wheelwells on my '60 Overlander are covered with a dried adhesive such as Parabond where a previous owner apparently attached some tire shades.
I have tried to remove it with mineral spirits and Walbernize but the danged stuff just won't go.
This pic doesn't really do justice to the prob since it was taken on a sunny day with shadows and the trailer has been walbernized since but may give you a clue to my prob. The holes are drilled where the shades were attached.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 08-11-2002, 02:38 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Lacquer thinner, xylene, Goop off? Wear good gloves.
John
74Argosy24MH is offline   Reply With Quote
Old 08-13-2002, 09:07 AM   #3
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Will the xylene harm the clear-coat? its strong stuff....I used some in the past on a car, and it didn't hurt anything, (and worked great), but I want to be sure before using it on the AS.....
Old 08-13-2002, 09:44 AM   #4
74Argosy24MH
Try it on some place inconspicuous, see what happens.
John
Old 08-13-2002, 10:07 AM   #5
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
You might also try Bestine...it's a rubber cement solvent that works really well on all kinds of sticky stuff.
Shari
P.S. Please let us all know what "works" for you...
Old 08-14-2002, 01:46 AM   #6
DIMMER
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
Try ZIPPO lighter fuel!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 08-14-2002, 10:07 AM   #7
cesurman
Profile:
I use 3M General Purpose Adhesive Cleaner, Part No. 051135-
08984, for all my adhesive removal jobs. So far, I have found no surface that was harmed by it.
cesurman
cesurman is offline   Reply With Quote
Old 08-17-2002, 09:48 AM   #8
Fatt Ratt
Fatt Ratt's Avatar
Profile:
Hey y'all,
I use Johnson & Johnson Baby oil to remove tar, road grime, oil and just about any kind of grim from my TT or classic cars. Mix into some Dawn or other mild soap then scrub. My college Chem. Prof. taught us this. - Ray
Cut to suit, Beat to fit, Paint to hide!!
Fatt Ratt is offline   Reply With Quote
Old 08-18-2002, 01:29 AM   #9
fuzzymoe
fuzzymoe's Avatar
Profile:
Thumbs up Sticky stuff
I got some stuff at Wal-Mart,don't rember the name of it,but it is a citrus combination of oranges.lemons,and other stuff. It comes in a small spray bottle and it's kind of orange in color.I didn't know the name of it when I went to get it but they did.It removed old duct tape that had been on my R.V. for a long time. It worked really well. If you can find this stuff let me know how it worked for you.
Fuzzy
fuzzymoe is offline   Reply With Quote
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 22 04-20-2008 11:30 AM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 09:15 AM
Window Removal Rob Windows & Screens 2 08-31-2002 07:49 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 02:22 PM
