Old 08-20-2010, 05:31 AM   #1
1978 28' Ambassador
Savannah , Georgia
Door trim gasket?
Finally removed all 8 rusted screws holding top trim/gutter/drip edge (didn't find the part listed in manual) over the entrance door. There seems to have been either a gasket or double stick tape behind this piece of trim that held it in place. Getting ready to reinstall and am confused if I need to replace this double stick tape. Know I will seal the top edge with Vulkem. The only double stick tape I can find is the foam type from the box store. Thanks for any help or guidance. Jack
Skamper1 is offline   Reply With Quote
Old 08-20-2010, 05:34 AM   #2
Originally Posted by Skamper1 View Post
Finally removed all 8 rusted screws holding top trim/gutter/drip edge (didn't find the part listed in manual) over the entrance door. There seems to have been either a gasket or double stick tape behind this piece of trim tha held it in place. Getting ready to reinstall and am confused if I need to replace this double stick tape. Know I will seal the top edge with Vulkem. The only double stick tape I can find is the foam type from the box store. Thanks for any help or guidance. Jack
Jack.
The vulkem only will work fine for the entrance door drip cap seal.
Old 08-20-2010, 05:51 AM   #3
1978 28' Ambassador
Savannah , Georgia
Thanks Andy. And I thought I was up early this morning!
Door gasket Sjean Doors & Locks 30 05-09-2017 10:47 PM
Door gasket mmcpherson 1969 Overlander 9 04-21-2010 10:35 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
'63 Door Gasket dieseleagle Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-16-2009 05:04 AM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
