Old 06-18-2011, 03:49 PM   #1
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Door Hinges look tired
Hello:
I've an '05 25' Safari. It's in pretty good shape except the bloody door hinges and the handle to the right of entry have lost the clear coat and look shabby. (oxidized).
Know how to strip, polish and coat.
Don't know if / how to remove inner door frame/for-head bumper to access fasteners with out damaging something.
Anyone done this before...advice??
Thank you
Del
Del Gurney is offline   Reply With Quote
Old 08-16-2011, 03:01 PM   #2
billiards's Avatar
rochester , Minnesota
door hinges/clean up
surie wish we could get some help on cleaning of oxid. d/hinges...have tried several cleaners ..none work..
billiards is offline   Reply With Quote
Old 08-17-2011, 03:49 PM   #3
Del Gurney's Avatar
1965 26' Overlander
They'll have to come off and be sanded down to like 1200 grit then put on a polishing wheel and clearcoated....my hands hurt thinking about it. In my youth on fancy yachts I did this all the time....it's a project.
I just want to know how to remove them.
Old 10-22-2012, 06:56 AM   #4
Turtle's Avatar
2004 16' International CCD
Arcata , California
I want to tackle the same problem. I was thinking of taping off the surrounding area and working on it in place. But a buffing wheel sounds a whole lot easier and I can see myself busting through the tape. It's a year later from the original post. Any new readers know how to get the door hinges off? Jamie
Turtle is offline   Reply With Quote
Old 10-22-2012, 07:25 AM   #5
dznf0g's Avatar
Oswego , Illinois
Pics might help, but if your hinges are like mine, you'll find plastic chrome strips on the back of the trailer side of the hinge, held on with double sided tape.
Strip them off and you'll see large phillips screw heads. Remove the screws and the hinge comes off the trailer. HOWEVER, I believe the nuts will fall inside the wall. There is an aluminum strip on the inside of the AS to the wall side of the door. If you remove it, I believe you have access to the inside of the wall there. I have heard others say you have to use a small hole saw to access the nuts under the strip. I'd look under here first before removing the screws.
I think you have to remove the inner door skins to get to the nuts for the door side of the hinge.
I would buff/sand them in place. Fabricate WOOD shields for the AS skin out of luan or other THIN solid material and tape them in place. That should protect the skin, even if you get unwieldy with the power tools. I would try a dremmel buffer wheel for the really tight spots.
Not an easy job, any way you look at it. I haven't done it yet, but I have been studying up and trying to muster the initiative. I'll bet it'll 4 - 5 hours each, minimum, just to prep them.
-Rich-
Old 10-22-2012, 11:38 PM   #6
Del Gurney's Avatar
1965 26' Overlander
Thanks Turtle and dnzfOg: I still am awaiting a way to really remove them with out polishing "in place" as I believe the oxidation will "work" it's way from under the hinges and I hate doing a 1/2 arse job.
On my TT it is obvious that I'll have to get to the nuts from the inside and it could be a nightmare if I make a mistake.
I had a PM from someone who did prep. and coat while they were left in place and it looked pretty good .... but still the chance of damaging the body panels if I "burn through" wood or plastic protective material will always be worry som.
And yes, the prep will involve at least a few hours for each hinge (assuming I punch out and replace the connecting pin).
Mine can not be the only TT with this problem so I await the advise of a professional who can tell me how to get the hinges off with out damaging the interior "mouse fur".
Cheers I'll post pics next time I can.
16" wheels/LT tires moosetags Wheels, Hubs & Bearings 955 12-17-2016 06:12 PM
Favorite Mod Under $100 Roscinante General Repair Forum 548 08-11-2016 04:43 AM
