Old 09-04-2008, 03:43 PM   #1
2007 25' Safari FB SE
Kennesaw , Georgia
Question Doh! Pine sap leads to light scratching!
Attempted to remove some pine sap on the exterior with some cleaner and a light abrasive sponge; pine sap came off, but then I noticed after it dried that the surface now has some light circular scratches in it now. This is an '07 25 Safari.
Any ideas how to clear this up?
Thanx, Lance
TennisMan is offline   Reply With Quote
Old 09-04-2008, 03:56 PM   #2
_
Originally Posted by TennisMan View Post
...Any ideas how to clear this up?....
1 or 2....
http://www.airforums.com/forums/f381...hes-37325.html
http://www.airforums.com/forums/f474...oat-43110.html
cheers
2air'
Old 09-04-2008, 06:18 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
margarine works great for getting sap of things, even your hands. and won't scratch....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-04-2008, 09:27 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Turpentine is the natural solvent.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-04-2008, 09:46 PM   #5
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Hello. My advice is to leave the scratches put. Or try a wax that will fill them in. You can always try a 3 m products called imperial hand glaze or Finnesse it 2. Keep in mind no matter what you use. You arent getting rid of scratches you are taking down the clearcoat/paint around it. Till all meterial is at the same level, then scratches are gone. You might try to touch the clear coat up also. Consult airstream about this. I am not a fan of thining the protectant. Good luck with this issue.
mustang is offline   Reply With Quote
Old 09-05-2008, 06:34 AM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Never and I mean never use even a light abrasive anything on a finish that you don't what scratches on.
I use very warm water (not hot), a smooth washcloth or sponge (non-abrasive) with Armor All Car Wash it comes right off without much effort and leaves no scratches to the finish.
About the only thing I could suggest is Walbernize super seal. It can take light scratching off the coating. I have seen it remove/fill some very light surface marks. Other than that, if Walbernize super seal won't help reduce the visible scratches, they'll be there as a permanent reminder never to use an abrasive anything on your exterior finishes.
Tree sap removal?? wyhjr Cleaning, Stripping & Polishing 32 03-05-2017 11:13 AM
Cleaning Plexiglass without scratching pagoff Cleaning, Stripping & Polishing 11 08-28-2007 05:38 PM
Have top half pine sap problem ernesto ca Cleaning, Stripping & Polishing 3 09-23-2006 06:00 AM
One leak leads to another... Buttercup Plumbing - Systems & Fixtures 24 12-08-2005 10:21 AM
Remove Pine Sap from Zip Dee Sav'h Steve Awnings 2 08-05-2003 04:05 PM
