Old 02-23-2013, 12:38 PM   #1
Cortaro , Arizona
Does Removeall work for metallic spray paint?
Hi! Yesterday we became the proud new owners of a '73 Overlander, and couldn't wait to get her home and start polishing her up. We quickly discovered, however, that the so-called "oxidation" on the aluminum is oxidized silver paint. We hope to bring it to a mirror finish one day in the not-so-distant-future, so any advice on how to treat this as gingerly as possible would be greatly appreciated! Thanks in advance---
Polly Esther is offline   Reply With Quote
Old 02-23-2013, 02:40 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Polly Esther!
Welcome to the Forums and the world of Vintage Airstream ownership!
The same removers that work with the usual PlastiCoat should work with most automotive metallic paints. The question in this situation is one of why the coach was painted. Airstreams may be painted for a number of reasons, some of which include:
  • Easier care an mainenance than a polished and/or PlastiCoated coach.
  • Effort to reduce repair costs through use of "typical" auto body repair methods to repair creases, dents, hail damage, etc.
  • Hide damage done by poor quality polish job.
Whether or not a mirror polish job is possible on such a coach hinges on the amount of surface scuffing/sanding that was done prior to applying the primer and paint as well as whether the paint is hiding repaired body damage.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 02-23-2013, 04:14 PM   #3
dznf0g's Avatar
Oswego , Illinois
I recently found out (thanks to a leaking container, and my stupidity of putting it on a shelf that overhangs my van hood) that acetone removes auto paint pretty well!
-Rich-
Old 02-23-2013, 04:20 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Kevin
It is also common to use an acid etching primer prior to painting.
Old 02-23-2013, 06:13 PM   #5
Chatthayer's Avatar
1972 25' Tradewind
Chattanooga , Tennessee
Images: 21
removall 220 will work great as it does on clearcoat. 1 and 1/2 gal for 2 coats on my 25' tradewind
Steve and Tobie Thayer
chatthayer@gmail.com
Chatthayer is offline   Reply With Quote
Old 02-23-2013, 07:10 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Concur With dznf0g, but...
Last year I backed over a can of spray paint on a very windy day.
My Suburban was instantly covered with forest green spray paint, dust, and tumbleweeds.
The acetone worked great when the paint was still freshly dried.
Unfortunately, I was lazy and none too thorough.
Now that the residual spray paint has cured, the acetone is no longer doing the job.
For your project, I would use paint remover, one panel at a time.
But heed what overlander64 has said.
You may discover dents that have been filled with automotive body filler.
This is a popular short cut to avoid the more expensive replacement of aluminum panels.
Fill it, sand it, paint it, sell it is the sad approach some have used.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 02-23-2013, 09:49 PM   #7
Cortaro , Arizona
Well, I will keep y'all posted on what lies beneath el bondo. Thank you for the great advice and anecdotal humor ("none too thorough"). I am sure that I have a treasure trove of anecdotal humor and aluminum wonders for you here in the near future.
