Old 09-09-2016, 07:16 PM   #1
alymorales's Avatar
2005 25' International CCD
Mission Hills , Kansas
Dent removal
Has anyone ever repaired a dent in their Airstream? I bought a "Super PDR" dent remover, but when it arrived in the mail, it didn't come with instructions on how to use it. I'm not having luck finding anything on the internet or the manufacturer website.
If you've successfully removed a dent from your Airstream, would you please advise on what the best tool is?
Thanks!
alymorales is offline   Reply With Quote
Old 09-09-2016, 07:38 PM   #2
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Suction cup worked for me
Old 09-09-2016, 08:29 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have a set of PDR hot glue sticks and puller "tabs". They did not work for my hail dents on my polished Airstream. The glue would separate before the metal moved. I tried different glues and tabs and pullers to no avail.
I had a big dent due to a construction cone. The suction cup had the strength for me to pull it out quite a bit. It would not repair creased metal, but did allow quite a bit of it to "oil can" back to form.
Some folks have good luck "rolling" a hail dent out from the inside. These are folks who have their trailers completely gutted, or are willing to take the interior apart to gain access to the dented area. I've read about metal rollers and even basketballs used to gently roll out the dent.
But by and large the best way to fix a dent on an Airstream is make an appointment with the factory at Jackson Center, OH. They can do any repair and make it just like new. Many Airstream dealers have body shops that can do the work. All you have to do is bring a big basket of $$$$$$.
Here is a photo of a trailer in the service shop when I was at Jackson Center getting my trailer repaired. I had a great experience with them.
David
Name:	1210 Rear Damage.jpg
Old 09-09-2016, 10:00 PM   #4
sealaker's Avatar
1993 30' Excella
Winter Park , Florida
Look up your local Dent Wizard shop. A friend of mine has used them with success on his Airstream. Turned out good.
sealaker is offline   Reply With Quote
Old 09-10-2016, 01:56 AM   #5
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Thanks!
Here's what I've done. If this does not all post with the photos, it's posts 30, 31 and 33 in forums, exterior, skin and rivets .
Originally Posted by Howard L. View Post
Attachment 266388Attachment 266389Attachment 266390
Above a photo of the basic gear I think you need for the hot glue PDR repair on small dents/hail damage. Look on Amazon, there are knock off brands of the Mini Dent Lifter. The total for what you see here will be around $100-150. It does pay to buy the best plastic puller tabs.
The work shown was on a contiguous pair of dents the size of a silver dollar and quarter. Not deep, just a pair of smooth indentations caused by my knee when a step ladder slipped. There are a number of good YouTube videos on the process. Here is a very good one:
Your results will not look like the pro finish work in the videos, but it will be fairly good. The "knock down" part is the most difficult. To make the dent disappear must take a lot of practice. In spite of the warnings above, the aluminum will pull just fine. What you must do is use a flat knock down point to re-flatten the metal. A pointed tool will make small dents in the aluminum while you are working to lower the newly created high spots.
Whether you use the mini lifter, or the pull handle, watch the metal as you start to apply pressure. If it looks like the aluminum has eased back out before the pull tab has popped off, stop and remove it with alcohol. Check, you may have already done enough. The larger the tab used, the more glue, and thus the stronger the pull. Since the "knock down" of the pulled area is the most difficult, try to correct with the pull just enough to get the job done and call it quits if you can.
After watching this video again, do not use a sharp snap to pull the glue tab. That's OK for steel, but for our aluminum, which is much softer, just use a slow pull while watching the surrounding metal. There is no need to over pull with a sharp snap of the puller or handle. You can re-glue and re-pull as many times as necessary without overdoing it using one big snap.
No, the glue will not pull the clear coat off--unless the coat is already compromised from underneath (in that case, a dent is not the worse problem). Use denatured alcohol to release the glue from the metal or pull tab.
As stated above, the Aluminum will not "knock" (tap) back down as well as steel will. Therefore, watch your pull and stop/remove tab when the dent looks pulled near flush. Pull again if not quite there. Better to make several easy pulls than to over pull and then have to knock the hump back down (over pull then knock back down is the procedure for steel). I know a pro can work the aluminum as well as steel, but AL is tough to work with for that final spotless finish-especially for a beginner. The dents I've worked out are probably 75-80%, where a pro's work would be 95%. Not even near perfect, but I have to look closely to see work on dents from dime sized hail, to a deep tennis ball size spot up high in back where dealer dropped an AC unit during install.
Looking for, but yet to find, a U Tube video on aluminum.
Howard L. is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 02:48 PM
Airstream Dent removal & Polishing Shimmer Cleaning, Stripping & Polishing 6 01-01-2012 12:36 PM
Dent Removal Steve Heywood Ribs, Skins & Rivets 21 06-18-2005 08:51 PM
Dent Removal/Hurricane damage ASFlorida25 Ribs, Skins & Rivets 11 11-18-2004 07:19 AM
dent removal nevisstudio Ribs, Skins & Rivets 8 01-14-2004 01:45 PM
