Old 02-24-2016, 07:36 PM   #1
1954 22' Flying Cloud
Kirkland , Washington
Deep Pitting in Alclad 2024-t3
Getting all geared up to polish. The major issue I'll be facing is where steel reflector plates used to be installed. My goal was to remove the reflectors permanently and fill the mounting holes with rivets. However, upon removal I was disappointed to find heavily pitted and rusted metal, where electrolysis occurred.
Most likely I'll need to put new reflector plates on to cover up the damage. I located some that are made of aluminum and they are very inexpensive. I decided for now to clean things up and see what I have to work with. Using a self made Dremel buffing wheel from scotch brite pad, I slowly removed some material and it is cleaning up nicely.
Now I understand that it will never be perfect, but if I am able to remove enough material to get a fairly smooth surface - will the pitted areas polish to some degree of shine? How different does the polished surface look: Alclad next to Alclad removed?
Of the six reflector locations, the one pictured below is in the most serious shape.
54fuselage is offline   Reply With Quote
Is 2024 t3 alclad mirror finish to begin with? Kingofbanff General Interior Topics 0 05-11-2015 09:50 PM
These deep deep scratches.. Stupidnoob Cleaning, Stripping & Polishing 43 05-01-2015 01:07 PM
2024-T3 alclad aluminum toastie Ribs, Skins & Rivets 6 03-31-2010 07:44 AM
Oven door, pitting balrgn Stoves, Ovens & Microwaves 3 07-21-2007 06:54 PM
Aluminum pitting on panels kenny2 Cleaning, Stripping & Polishing 3 02-19-2005 01:12 PM
