Old 01-30-2011, 01:13 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Deep Dimpling
I have some very very very bad dimpling on my door between the handle and the dead bolt. How can deep pitting or dimpling be removed? I ran the compounder over this area multiple times and its just not cutting it. Can I wet sand it? Will it help? If yes what grit?
Thanks.
ID:	120506   Click image for larger version
ID:	120508   Click image for larger version
NicheVintage is offline   Reply With Quote
Old 01-30-2011, 01:24 PM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Did you remove the clear coat 1st? Have to remove the clear coat and then follow with compounds.
SilverHoot is offline   Reply With Quote
Old 01-30-2011, 01:26 PM   #3
1965 26' Overlander
Images: 34
Yup. Whole thing has been stripped.
Old 01-30-2011, 01:28 PM   #4
1965 26' Overlander
Images: 34
The first pic is after compounding you can tell a very slight subtle difference.
Old 01-30-2011, 01:47 PM   #5
SilverHoot's Avatar
1967 24' Tradewind
I have some areas on mine with a similar appearance and was able to remove with multiple (>4 ) passes with Nuvite F7.
Old 01-30-2011, 03:52 PM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I`ve had to use a very fine wet sanding to get out spots like that,then run over it with you compounding. Dave
easyride is offline   Reply With Quote
Battery lost a cell. Desulfating or refurbishment possible? Keyair Batteries, Univolts, Converters & Inverters 57 02-14-2011 11:26 AM
2011 Mid Winter Meeting wkerfoot WBCCI Forum 372 02-07-2011 02:07 PM
AGM equivalent? UAPachyderm Batteries, Univolts, Converters & Inverters 22 01-31-2011 08:44 PM
Couple Sues Walmart FLYNCLD Off Topic Forum 55 01-05-2011 01:12 PM
