Old 09-10-2007, 08:12 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Decal Removal Help
We have an Excella stripe on the tank cover that was chewed up a little so I decided to replace it with the same striping. Thought I'd knock most of it off with a heat gun tonight (Airstream advised to do it this way) - NOT.
This is 45 minutes of work. Am I doing this wrong - should I be heating up a larger area from the backside and then trying to peel it off. Any thoughts appreciated......
Old 09-10-2007, 09:29 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I just tried some stuff called " Colonel Brassy" cleaner and polish. It worked better than anything else I have tried on the 36 year old red letter and WBCCI sticker residue on my 71. I got it at the town auto parts store but it is available on their website Vertex Industries, Inc.
Old 09-10-2007, 09:44 PM   #3
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
On our 96 Excella we recently used a hot iron (yes clothes iron) with a wet towel between it and the decal, held it on, moved it, then peeled off the decal. It comes off easily that way bit by bit. You have to hold the iron in one spot and then move it, we had to remove the swoopy graphic decals from both sides of the trailer as well as the decals along the top. Then we used WD 40 to get the residue off. Good luck with your project.
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 09-10-2007, 10:04 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
The hot iron with a wet towel worked best for me too. I used stripper & a razor scraper to get the glue off. Have fun!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-11-2007, 01:02 AM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Heat is a good start. It will loosen the glue and release the graphic. However, now you have the gooy stuff left. Try Gasket Remover found in auto supply stores. Graphiti remover, Goof Off will work to a degree. I square off a tongue depressor to use as a scraper. It will minimize scratching your aluminum. That glue stuff will not let go easily so stick with it. Pun intended.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-15-2007, 01:47 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
OK - the decal face is off but it left a kinda foil backing adhesive. Also, decided to strip the clear coat off to polish and then reapply. If this is any indication of what it's like to strip a trailer - then mine will go to the Mother Ship for that job. Thanks for letting me vent.....
Old 09-15-2007, 05:08 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
It's nothing like stripping the clear coat off a trailer. It doesn't come off the cover as easily as the trailer because the cover (at least mine was) is more heavily etched in the metal. I think it might even be stainless (you have to search on that fact). The trailer is a piece of cake--just a little patience!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-15-2007, 05:47 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks Becky. Not sure what it's made from but I really screwed it up. Used stripper, that was a pain but finally worked after 3 coats. Then I hit the adhesive with oven cleaner whick worked great. Only problem is it turned the stripped metal cloudy and streaky. Trying to buff it out with tool box polish - we'll see.......
Old 09-15-2007, 05:59 PM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
And that just made it worse - now it's streaky and has black stains....
Son of a pup......
Old 09-15-2007, 06:28 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
Try cleaning the black stuff off with mineral spirits. I'm not sure what's in the oven cleaner--didn't try that, but did try to polish mine & it didn't do a thing (that's why I think it's stainless).
Becky
1964 Bambi II
1988 Avion 32S
Old 09-15-2007, 06:41 PM   #11
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Think your right - it must be stainless under a clear coat like the rock guards. I may have just ruined a what 3 or $400 cover......
Old 09-15-2007, 06:52 PM   #12
Becky B.'s Avatar
1964 17' Bambi II
Maybe you could take a piece of very fine sandpaper & run with the grain & try to sand out the black streaks (if all else fails). That's what I did with my stovetop & the rust & black marks all came off very nicely. Good luck!
Becky
1964 Bambi II
1988 Avion 32S
AIRSTREAM decal ricochet Clearcoat, Exterior Paint & Trim 3 04-07-2007 11:51 AM
AIR decal davidz71 Our Community 4 09-02-2005 11:43 AM
Decal Over59 Community Polls 41 04-01-2005 06:37 PM
Woodgrain Decal Help? jthew1 General Motorhome Topics 33 01-18-2004 05:04 AM
logo decal for AirstreamForums.com carmen Our Community 6 10-07-2002 04:36 PM
