Old 09-05-2008, 03:57 PM   #1
Dick
1987 31' Excella
Fountain Hills , Arizona
Decal Removal
What is the best way to remove old Decals?
Dick Lofland is offline   Reply With Quote
Old 09-05-2008, 04:15 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome to the forums!
When you say decals, are you talking about the red (WBCCI) numbers on the ends of the trailer?
Richard
Old 09-05-2008, 04:15 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Orbital Sander with 80 grit....
Just joking.... What kind of Decals different stuff works on different thing GOO works on must stuff...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-05-2008, 04:33 PM   #4
Dick
1987 31' Excella
I am talking about the 6 1/2 inch wide blue decal that extends all the way around some of the older Airstream Excella models.
Thanks, Dick
Old 09-05-2008, 04:56 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a link to another thread with the same question. If yu do it this weekend, you should not need a heat gun...
http://www.airforums.com/forums/f474...cal-37546.html
Richard
Old 09-05-2008, 05:10 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Hey! My parents live in Fountain Hills! Say "hi" to them for me ~
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-05-2008, 06:09 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used a wet rag & an iron to remove mine. Tried the heat gun, but it got too hot & melted the decal. With the rag under the iron, you heat up a section & peel it up before it gets too cool. Worked great.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-05-2008, 07:03 PM   #8
RBolton's Avatar
Belington , West Virginia
Heat guns are tricky. You can control the temp either with the temp setting on one with variable temp switch or just by holding the gun further from the area you are working. Don't get it any hotter than is necessary. Very warm is usually hot enough. Heat a few inches at a time. Peel or scrape off with a plastic blade of some sort. Don't use the heat method to remove the glue residue. Remove the glue with a solvent.
3M makes a spray on stripe remover. Sometimes takes several application and is sort of messy. Best to mask off surronding area. You will still have the glue to deal with.
Roger
RBolton is offline   Reply With Quote
Hood Decal gascpa Vintage Kin 2 07-22-2008 05:56 PM
Remove Decal Pete Salvesen Clearcoat, Exterior Paint & Trim 5 12-29-2007 07:32 AM
Decal Removal Help Ganglin Cleaning, Stripping & Polishing 11 09-15-2007 06:52 PM
Decal Over59 Community Polls 41 04-01-2005 06:37 PM
Woodgrain Decal Help? jthew1 General Motorhome Topics 33 01-18-2004 05:04 AM
