Old 06-04-2012, 04:24 PM   #1
Laff67safari's Avatar
1967 22' Safari
Zanesville , Ohio
Cyclo 5
What's the secrete?
Laff67safari is offline   Reply With Quote
Old 06-04-2012, 05:25 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
It's random dual pad action removes swirl marks left by other polishers.
Perfect Polish
Shari
Old 06-05-2012, 04:39 AM   #3
Taylormade's Avatar
1978 31' Sovereign
Man, seriously vague question. If you've purchased one and can't figure out what to do with it, here are a few things to consider:
Use a small amount of polish. A dab on each side will suffice just fine.
Change the covering materials frequently. Whether that's t shirts, fleece, etc, either move it around or change them out after a 4x4 section.
Move the cyclo around quickly. Work in a 3x3 section and move the cyclo around rapidly. This is the opposite from when you're using a heavy cutting compound.
If you explain the question a little more, I'm sure you'll get a better, more informed response.
Taylormade is offline   Reply With Quote
Old 06-09-2012, 07:58 AM   #4
1967 22' Safari
Zanesville , Ohio
Im new to the world of Airstream. I have found a Cyclo, where is the best place to find all the other material needed?
Old 06-09-2012, 08:03 AM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
The link I provided in post #2 or Vintage Trailer Supply.
Shari
