Old 07-24-2011, 07:20 AM   #29
Baltimore , Maryland
Brad, I have that guy just North of me. Unfortunately the last 10% must be done by me. My standards are just a little higher.
Old 07-24-2011, 08:33 AM   #30
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Gojo
I used Golo hand cleaner to clean off the dirt and corrosion before gray bar.It smoothed and lubricated the surface somewhat.
bwaysteve is offline   Reply With Quote
Old 07-24-2011, 11:08 AM   #31
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I found the aluma bright to be somewhat mild, it did nothing to the glass and did brighten up the skin. I covered my plexi window though.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-24-2011, 04:48 PM   #32
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
And where are you buying alums right?
Darkspeed is offline   Reply With Quote
Old 07-25-2011, 04:40 PM   #33
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Aluma- nator came through a web site I found here..
Aluminator Aluminum Oxide Remover and Aluminum Brightener
AIR #005
retired!
Old 07-25-2011, 04:49 PM   #34
NAPA has the stuff. Freightliner has the stuff too. There are many brands of the same stuff.
Old 07-25-2011, 06:20 PM   #35
Chatham , Ontario
Hi I just purchased a 1983 31' Diesel Motor home and I am in the process of trying to restore it a little better, I have a son-in-law who works for a company who has a fleet of trucks and they use an alum. cleaner called T.C. 310 and his drivers swear by the result.
I tried it with an electrical water pressure and the results were not very good, so tomorrow I am renting a 2600 psi washer in hopes that it will do the job, I will keep you advised of the results
Ken
kenjoe is offline   Reply With Quote
Old 07-25-2011, 06:59 PM   #36
it will be 100% ineffective. You need to remove the clear coat first.
Old 07-25-2011, 09:58 PM   #37
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Ken
If you are trying to remove the old clearcoat, you HAVE to use a stripper. Clearcoat has got to be one of the toughest things known to man. You cannot pressure wash it off, or "polish" it off, even with the most aggressive grade of Nuvite (F-10). Get hold of some "Removall". It will lift the clearcoat with ease, THEN use your pressure washer to blast off the residue.
streamquest is offline   Reply With Quote
Old 07-25-2011, 10:52 PM   #38
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
kenjoe - When you've used the Removall to remove the clearcoat, if you want a shine you'll still have to use one of several methods discussed here (both products & tools) to remove your Moho's oxidation. Then you'll need to use other products & tools to achieve that mirror shine. Lots of time & work, but sooo worth it. Post photos as you progress.
I love that old time rock & roll.
whitsend is offline   Reply With Quote
Old 07-26-2011, 07:16 AM   #39
Chatham , Ontario
Thanks for the tip on clear coat removal, any product name would sure be helpful I am like a baby just starting to walk the info is over whelming
Old 07-26-2011, 07:26 AM   #40
Chatham , Ontario
I have been reading so much information about restoring it's hard to take it all in, so as I understand it I have to remove the clear coat 1st and then apply the TC310 alum. cleaner and then polish it to seal it.would appreciate any tips on restoration as well as what products seem to work the best
Old 07-26-2011, 07:29 AM   #41
you want the strongest most nuclear stuff possible. Aircraft stripper works for me.
Old 07-26-2011, 08:36 AM   #42
Chatham , Ontario
Thanks for the tip ,any idea where this can be purchased this product and any ideas on the Removall product some are talking about
Polishing in the midwest? aventine Cleaning, Stripping & Polishing 2 06-28-2011 08:58 PM
Polishing service in Austin TX. ? Mus289 Cleaning, Stripping & Polishing 1 03-01-2011 11:04 AM
