02-26-2012, 03:24 PM
1975 27' Overlander
Englehart
, Ontario
Couple questions - polishing
For Christmas I received the jestco polishing kit. As it is still winter here, and I'm getting bored, I decided to try polishing the propane tanks. The first one I just used the grey bar, then the pink bar. Then cyclo. Experimenting with the polisher, wheels etc. it took a lot of polishing to get it shiny. The next one. Sanded with 400, then 800 grit first, then hit it with the polisher. Same result but less time. There are still "marks" in the aluminum, looks to me like the metal got stressed when it was bent to form the tank. Verticle lines that I can't get rid of. They are pretty shiny, but not "perfect". Is this as good as they get? Then I took of the small fridge access door and stripped the clearcoat, then polished it. Again, it's pretty shiny but not "perfect", not sure if I am expecting too much. It is very shiny, but still has a few blemishes, marks in it. Wife is quite happy with the result, me not so much. Should I be expecting a perfect "mirror" finish?
Also the Overlander has cast aluminum wheels, can they be polished too?
02-27-2012, 04:14 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
With a mirror finish, most strive for "perfection" at 5, 10 or 20 feet, meaning it looks "perfect" at that distance. But while actually polishing, you're only at 12-24 inches - you're going to see imperfections at that distance that you won't farther away. It's never going to look " perfect" at those close-up distances.
The thing with the tanks is, they are not Alclad aluminum like the skins, so they won't polish up quite as shiny. The skins have a "more pure" aluminum surface which achieves a brighter polish than the tanks which are a different alloy. Once they are on the trailer and the whole thing is polished, it will probably look a lot better than sitting by themselves.
One more thing, the '75 skins have a different mill finish to them than the 50's & 60's trailers - they can still be brought to a mirror shine, but it takes more effort to get through that milled finish - whereas the old skins are slightly smoother to begin with.
Keep at it and know that each year you touch it up, it'll get better.
Shari
02-27-2012, 05:44 PM
1975 27' Overlander
Englehart
, Ontario
Try to figure out this picture thing.
02-27-2012, 07:04 PM
1964 17' Bambi II
Schererville
, Indiana
Cute Weimaraner! I think your access door looks great!
Becky
1964 Bambi II
1988 Avion 32S
02-28-2012, 08:36 PM
1972 27' Overlander
Penokee
, Kansas
Mine next?
Got the power cord out by my new 1972 Overlander and needs a good shine.. You could use mine to lean how and then do a bang up job on yours..
Sodbust
02-28-2012, 09:28 PM
Folsom
Looks like Northlander is snowed in!!! Might want to send your little doggie for help....or not...
02-28-2012, 11:52 PM
1956 22' Safari
Conifer/Evergreen
Me too!
Shari
02-29-2012, 08:41 AM
1975 27' Overlander
Englehart
, Ontario
Thanks for the positive comments.
I have only seen pictures of polished Airstreams, and they sure look nice in the pictures. I would like to see one in person.
We are snowed in for a while yet, as you can see. I am taking the other access door off and will polish it as well. Not much else I can do until spring.
02-29-2012, 11:43 AM
1964 17' Bambi II
Schererville
, Indiana
I can tell you that most of the polished AS's look better in a photograph than in person. You can go to a lot of different levels in your polish job. With your own eyes, you can see the cloudiness, or lack of it, while you work. In a photo, those imperfections aren't picked up. So, while you might think all of us who have polished trailers have absolute mirror, I'll be the one to say, they all aren't perfect (at least mine weren't!)
Becky
1964 Bambi II
1988 Avion 32S
02-29-2012, 12:46 PM
1965 22' Safari
Vassar
, Michigan
I agree w/Becky. My 65 looks like a perfect polish job from 30' away. The closer I get the more flaws I see. When polishing I found that it really helped me to take a break and step back away to see my work. Once all the compounding was done I got pretty good results using Nuvite S with the Cyclo. In some places 2 or 3 passes to get all the swirls out.
Tim
TAC MI 14
Everyday is a Saturday
04-26-2012, 01:36 PM
1975 27' Overlander
Englehart
, Ontario
Spring has sprung, and I have started stripping. Sure wish I could buy citri-stip or removall in Canada. I have tried a few different strippers, none work as well as what those two sound like they do.
Another question, do I whack off the airstream letters with a putty knife like Andy says, or leave them on and fuss around them?
04-26-2012, 01:45 PM
1982 34' Limited
Brunswick
, Georgia
I worked around mine... its not perfect but still looks good. you can get the "mushrooms and other funny shaped polishing tools for your drill at Vintage Trailer Supply; that is good for the letters and other tight spots. I got as close as I could with the buffer and a wheel, then tried some nuvite by hand. again... not perfect, but good enough.
I would try working around them first, then if you dont like the results, take them off and polish.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
05-07-2012, 09:57 AM
1975 27' Overlander
Englehart
, Ontario
jestco grey bar
How shiny should it be with the grey bar? I'm finding that if I spend lots and lots of time with the grey bar, I can get it really shiny, and even looking. But am I wasting my time? should I just be using the grey bar to take off the bulk of the surface, not worrying about it looking too good, and then will the pink bar/cyclo will do the rest. And when do I throw out the buffing pad and switch to a new one? I've got the whole rear done with the grey bay now.
05-07-2012, 11:08 AM
1968 24' Tradewind
Oxford,
, Mississippi
I used both Nuvite and the jestco system on my TW. A word of caution. I think, but can't prove because I don't have a lot of before pictures, that the jestco heated up the skin in places around the rivets and caused some dimpling. It does not look good and on the top where I only used wool pads and Nuvite I do not see the problem. The jestco cuts faster and does a good job but just watch the heat. Again, I can't prove that what caused the dimpling effect around the rivets on the side. It may be just the shine allows me to see the blemishes.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
05-07-2012, 12:40 PM
1982 34' Limited
Brunswick
, Georgia
My AS has dimples at the rivets too. I used the wool pads/ nuvite. I think they were always there, you can just see them better now. I didnt really think about it until you mentioned it. It is very consistent on mine and looks like it is supposed to be that way. Of course I have 34' of it which may make a difference in the consistency factor.
1982 34' Limited
WBCCI #3321
TAC #GA-24
06-12-2013, 09:06 AM
sunny 75
1975 27' Overlander
selah
close enough to perfect for me
Thank you for admitting in writing that the mirror finish is not perfect. That is an unrealistically high standard and may cause some people to give up (or sit down and cry, in my case). You are right that in pictures the inperfections don't show up. Also, stepping back often while working is a good tip to keep up your morale. When you are finished you won't even notice the "not perfect spots" because the total effect is stunning!
