Old 07-10-2004, 04:25 PM   #1
compound/steel wool ?
hi,
wondering if it is okay, or not recommended, that i use a compound and/or steel wool on the exterior skin? i have three different washers/polishes from airstream.com, however i have a couple of trouble areas (it looks as if something was sprayed on the skin that has caused imperfections) that i think a compound and/or steel wool might take care of. much appreciated.
thanks,
glen
gmprejean is offline   Reply With Quote
Old 07-10-2004, 04:28 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
What kind of compound are you using?
Lite sanding is ok with 1200 grit or above, just be careful not to over do it
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 07-10-2004, 04:58 PM   #3
Haven't purchased a compound yet. Let me know if you have any recommendations. Thanks for your input.
Glen
Ken
Old 07-10-2004, 06:49 PM   #4
Ken J's Avatar
Durango , Colorado
Images: 14
Tell me a little more about what your doing - what year is your trailer - does it have clearcoat on it? If it does not then I would use either Nuvite or Rollite products.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 07-10-2004, 08:47 PM   #5
1960 Tradewind
It's a 1960 Tradewind, so if I'm not mistaken it does not have clearcoat. I just purchased it (my first Airstream) about a month ago, and so far all I've done is washed it and I'm almost finished using Walbernize (the one step cleaner polish and glaze Airstream recommended for a '60) for the first polish or pre-polish. I also have a can of Met-All Aluminum polish and a bottle of White Diamond metals polish which were also purchased on the Airstream site. I'm basically trying to get it cleaned up and looking good. I appreciate your time and insight.
Glen
Ken
Old 07-11-2004, 07:47 AM   #6
Ken J's Avatar
Durango , Colorado
Images: 14
Glen - a 60 tradewind - major cool. I looked everywhere for one of those, ended up with my 58 overlander.
Anyway should not have clearcoat on it. The way to find out is take a bit of toothpaste and rub it on - if your cloth turns black - there is no clearcoat.
On those old trailers you need something a bit more aggressive than what your using - look at www.airstreamdreams.com - they have both Rollite and Nuvite products. I would suggest you get there sample pack which has all grades of polish/compound and start polishing away. What you want to do is try the least agressive polish first, if that doesn't work, then go to the next agressive.
There has been a lot of discussion about polishing on this forum - may want to do a search - you'll get lots of opinions. I only use aircraft approved polish - you don't want to use any acid on your trailer - causes leaks.
Welcome to the forum - keep asking away, and...... send us pictures!
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
To all owners of vintage units altastars General Interior Topics 36 05-07-2004 10:37 AM
wood stripper recommendations fitzjo1 Cabinets, Counter Tops & Furnishings 24 01-24-2004 04:59 PM
Southern Shine - need the directions again... drboyd Cleaning, Stripping & Polishing 4 09-20-2003 01:06 PM
Polishing Windows and Trim LeeA Cleaning, Stripping & Polishing 6 07-15-2003 04:49 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
