Old 05-17-2010, 04:48 PM   #1
Titusville , Florida
ClearCoat Stripping
What is the best Clearcoat stripper? I used some Aircraft stripper I bought at walley world(Wall-Mart), it took off the glue on the back of the vinyl numbers and that was about it. I let it sit on the finish the recommended time the first time, longer the second time and even longer the third time, and still did not take off the clear coat, and yes I put it on thick.
Recommendations on strippers and what to do with windows Ect.
93 25ft Excella.
Caltech is offline   Reply With Quote
Old 05-17-2010, 05:39 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Removall 220
'77 Sovereign Intl 31' CB
Old 05-17-2010, 06:01 PM   #3
RBolton's Avatar
Belington , West Virginia
Zip-Strip
RBolton is offline   Reply With Quote
Old 05-17-2010, 07:54 PM   #4
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Kleen Strip from Lowes!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-18-2010, 07:59 AM   #5
1973 31' Sovereign
1958 22' Flying Cloud
San Angelo , Texas
ClearCoat Removal
Am using CitriStrip from Home Depot. Just 30 minutes before it's ready to spray off with water. Takes only one application. Just be sure to apply when outside temp. is below 85 as recommended. One day I didn't and it was hard to remove. Otherwise it's been very easy.
Joy M is offline   Reply With Quote
Old 06-22-2010, 01:55 AM   #6
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Removal 220. I got mine from Vintage Trailer Supply... Biodegradable, simple, works fast and thorough. Messy.
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 06-22-2010, 06:49 AM   #7
Central , Mississippi
We are pretty happy with this method.
http://www.airforums.com/forums/f205...tml#post857709
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-22-2010, 08:07 AM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Aircraft Stripper
93 25ft Excella.
The Aircraft stripper that works has a blue can with an airplane on it.The one you get at Auto Zone says "low odor"and not as effective.This one is a different formula.I got mine at a body shop supply house.There is a difference.
I tried Citristrip and it worked ok,but dried out pretty quick.
bwaysteve is offline   Reply With Quote
Old 06-23-2010, 06:12 AM   #9
Thanks for all the info everyone, when I get started I will post pics to show you how it looks before and after. Thanks again.
Ron & Margie
93 25' Excella
Old 06-23-2010, 07:01 AM   #10
funkill's Avatar
reno , NV
Images: 27
Hi Ron & Margie ---
I'm in T-ville too. And I just finished stripping my trailer a couple weeks ago. I used the RemovAll 220. My first application removed about 80%. Took me several spot-applications to get it all off. It came off in sheets - reminded me of peeling after a bad sunburn. I wish I had taken Before & After and During pics but my camera was out of service. She is really much better looking now. I did a lazy-girls application of wax (spray on wax) to hold until I figure out what to do next. I can't even imagine a full polish job in this heat. But I have some bad oxidation at the top and would like to just get that off ASAP. I'm thinking about my options. Even bought a small bottle of GoJo pumice after reading about anothers' positive findings with oxidation removal.
Hope you have some good results with your stripping.
Laura
funkill is offline   Reply With Quote
Old 06-23-2010, 02:38 PM   #11
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Just used a new product Rustoleum Airceaft Stripper.Left on 5 min. and it ate through clearcoat and I hosed off.Faster than anything I have used so far.
Old 06-23-2010, 07:00 PM   #12
In the heat, I found a good method...several coats of citristrip in rapid succession...stir with a semi soft brush until the clearcoat/stripper is a gooey mess, then rinse it off. Takes about 15 minutes to strip a section, which is about all ya wanna do in 90+ degree heat
Stripping Clearcoat for Aluminum Mag wheels? 72Blazerod Clearcoat, Exterior Paint & Trim 1 02-02-2010 11:38 PM
Stripping? b1ejfx10 Cleaning, Stripping & Polishing 8 04-22-2009 02:45 PM
Stripping 53flyingcloud Cleaning, Stripping & Polishing 22 02-18-2009 08:20 AM
stripping clearcoat on decals glacierrunne Cleaning, Stripping & Polishing 0 05-27-2006 09:49 PM
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 07:59 PM
