Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 08-29-2007, 10:05 PM   #1
equigley
Profile:  1971 23' Safari
MUSCLE SHOALS , Alabama
Clearcoat Removal
I am a newbie and a more confused than ever on the subject of clearcoat removal and what to do next.
I have a 1971 Safari 23' with deteriorated clearcoat. I plan to use Napier Removall 220 stripper. Now, for the what to do next question-I prefer not to spend the time or the money required to polish to a mirror finish-at least for now. Can I not just for the sake of protecting my Airstream from further (and or future) corrosion damage by removing the clearcoat and then simply waxing. If so, what is recommended?
Also, has anyone heard of or used a product called Alodine 1001 (brightens aluminum and protects from corrosion) from Aircraft Spruce & Speciality Co. ?
equigley
equigley is offline   Reply With Quote
Old 08-29-2007, 10:08 PM   #2
StingrayL82
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Haven't heard of it, but there's a guy in Gilroy, CA who has a company that specializes in cleaning metal, specifically anodized aluminum. I had a 1968 Streamline (anodized aluminum trailer) and I took it to him to get the yellowing out. The trailer was spotless, when I got it back. Here's the link:
metal wax.com
Frederic
SSG Frederic Lynes
1971 31' Sovereign, restored
2004 F350 King Ranch
StingrayL82 is offline   Reply With Quote
Old 08-29-2007, 10:44 PM   #3
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Alodine is NOT a wax. It is a chemical reactive coating it bonds to the aluminum. This is how they made Wally's golden trailer.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 08-30-2007, 05:24 AM   #4
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
metal wax.com
Frederic
I used it, great stuff about 40 hours for 31', the part that has the clear coat removed will go very fast with metal wax, the parts you may have with some corosian used red compound on first, than metal wax.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 08-30-2007, 08:14 AM   #5
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I, like thecatsandi, Initially thought NO on the Alodine 1001. But then I got to thinking (it happens) and the Alodine that I've been using for years and years is Alodine 1200 or 1201 and I had never heard of 1001, So I looked it up and was somewhat surprised at what I read. It Reads "An invisible coat to provide in-depth corrosion proofing to the brightened aluminum surface and act as a firm (film ?) barrier against the elements and continued corrosion). I might buy a qt. and see what it does to a bare piece of aluminum. I guess I'm never to old to try something different and new to me.
Old 08-30-2007, 12:39 PM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Alodine 1001
NOT ONLY NO, BUT HECK NO !!!
We just picked up a quart of Alodine 1001 from Aircraft Spruce.
Cost $ 16.30.
The WARNING LABELS state the following.
POSSIBLE CANCER HAZARD: Contains chromic acid which may cause cancer. Risk of cancer depends on duration and level of exposure.
WARNING: May cause eye burns and skin irritation. Harmful if sqallowed. Contact with organic materials may cause a fire after evaporation of water. Contains acidic chromates and Fluorides.
Avoid contact with eyes, skin and clothing.
Avoid breathing mist from solution.
Avoid contact with combustible materials.
In case of contact flush eyes or skin with plenty of water for at least 15 minutes.
SKIN CONTACT: Immediately take off all contaminated clothing. Flush with large amouints of water. Soak the affected area for one hour in an iced solution of (0.13 %) of Zephiran chloride (30 cc of 17% concentrate per gallon of iced distilled water.)
GET MEDICAL ATTENTION IMMEDIATELY.
Remove contaminated clothing and/or shoes. Wash clothing before reuse.
DISCARD contaminated shoes.
Also comes with six pages of "material Safety Data Sheet."
Lastly. FOR PROFESSIONAL AND INDUSTRIAL USE ONLY.
Hope this helps those that may have considered using this material.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-30-2007, 01:44 PM   #7
equigley
Nix The Alodine
Thanks Andy for the reply on Alodine. How is something like that is even on the market?
So now back to the original question. What can I use to protect the trailer after removing what is left of the clearcoat (keeping in mind that I am not prepared for polishing as yet)?
equigley
Old 08-30-2007, 02:05 PM   #8
Commercial Vendor
equigley
You can use a good automotive paste or liquid wax.
Walbernize is for the clear coat, not aluminum.
Andsy
Inlandrv.com
800-8777311
Old 09-06-2007, 08:43 PM   #9
vintagemike
Profile:  1971 25' Tradewind
St. Thomas , Ontario
re: Napier Removall 220
I can't say enough about how great that product is. I stripped my 25 foot Tradewind in one day with Napier Removall 220. I had tried several other products on the inspection covers and found it to be a lot of work wiping and scraping the sticky paint removers. The Removall could be left on four hours and I just powerwashed it off. The aluminum under the clear coat looked great. I almost decided to forget about polishing it and just leave it stripped.
I googled "Napier" and got a number in Quebec and they then directed me to the closest distributer. I had the product in four days. I used one gallon at about $75 to do the whole trailer. I needed every drop though, not a bit of extra. BTW this was a 1971 trailer with nearly perfect clear coat.
Vintagemike
vintagemike is offline   Reply With Quote
Old 09-06-2007, 09:07 PM   #10
SwampBillies
SwampBillies's Avatar
Profile:  1972 31' Sovereign
1964 24' Tradewind
Plant City , Florida
VintageMike
We looked for the Removall 220 at ICI paints which was where I was told to get it. They told us it had been discontinued. We did find a branch that still had 2 gallons on the shelf, but after driving over an hour to get there we discovered it was old and had broken down. Wasted trip. Very dissappointing after all the good things we have read about it here.
Debbie
Never argue with an idiot. They will drag you down to their level, then beat you with experience.
Debbie & Lewis Adkins
WBCCI #15754 --- AIR #18873
1972 - 31' Sovereign International (Betty)
1964 - 24' Tradewind (Glory)
2002 Ford F250 Super Duty
SwampBillies is offline   Reply With Quote
Old 09-28-2007, 10:24 PM   #11
PolisherGuy
THIS OLD TRAILER
PolisherGuy's Avatar
Profile:  1969 27' Overlander
Young Harris , Georgia
Use Aircraft Stripper at most any auto parts start .
Read the directions. Just brush it on. Let it sit for 30min.
Then agitate with brush and hose off. Want a mirror shine?
Check this out.....DVD Polishing Guide
PolisherGuy is offline   Reply With Quote
Old 10-02-2007, 01:42 PM   #12
dklimek
Profile:  ogden , North Carolina
So is there no hope in finding the removall 220 if you are looking to buy it local? I would rather use this product, as i have read you dont have to run around the camper scraping all off...and i have a few airstreams to do so it would save me alot of hassle.
dklimek is offline   Reply With Quote
Old 10-02-2007, 03:33 PM   #13
dklimek
Also, i have read alot about polishing the campers with nuvite...where can you get this?
Old 10-02-2007, 03:34 PM   #14
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
I don't know about the local issue but vintage trailer suppy carries it. Works great and in friendly to the environment
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 03:31 PM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 10:15 AM
Washing/waxing "new" clearcoat Kistler 2003 International 13 11-21-2002 10:27 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 08:01 AM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 03:22 PM
