Old 03-14-2014, 01:23 PM   #1
1972 31' Sovereign
Santa Rosa , California
Clearcoat Removal
I have read somewhere that a clear coat remover had been used that you apply
at dusk and hose off at dawn. Does anyone know the name of the product?
Qgson is offline   Reply With Quote
Old 03-14-2014, 02:35 PM   #2
1988 25' Excella
Trumbull , Connecticut
Clearcoat Removal.
Hello fellow Streamer. When I had my 88 recoated at P&S, in Ohio, they stripped the old clearcoat off with lacquer thinner. I ask Steve how he kept the place from blowing up as the lacquer smell was so strong that it made the eyes water, and he said everybody was especially carefull during the stripdown process. I guess they must be as P&S has been doing airstream for many years.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 03-14-2014, 03:14 PM   #3
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Check out this video:
Airstream Planet Polishing Part 2 - Episode 1011
Our Videos - Airstream Caravan - Dressing Room - Hofmann Architecture
Evidently Santa Barbara has perfect weather for dusk application and dawn removal.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 04-20-2014, 09:37 PM   #4
1969 27' Overlander
Sunny Skies , Rockies
I used the Home Depot stripper then used the power washer 30 minutes later. Did individual sections and went pretty quick. The key to it is the power washer.
I started using a plastic scraper etc based on the stripper directions and that took forever. The power washer took about 25 percent of the time.
Good luck!
Marcello is offline   Reply With Quote
Old 04-21-2014, 08:43 PM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Citrus strip from the hardware store works fine. "Aircraft Stripper" from the auto parts store is better, but really nasty. The pressure washed helps. 30 minutes is all you need.
Old 04-30-2014, 11:26 PM   #6
maggieevans's Avatar
1966 24' Tradewind
Burnaby , British Columbia
For years, the "go-to" product was "Removall". No longer made. Now the best product is apparently Eldorado PR-5044. It is sold by Vintage Trailer Supply. And yes, it is the product that you apply at dusk and remove in the AM. Problem is, it is also almost impossible to get. It was being sold in 1 gallon bottles by VTS and a few others, but apparently they can no longer get a supply. It appears that the only way to get it now is in a 5 gallon bucket from a wholesale distributor.
I am planning to do my trailer soon, and have decided to go with an aircraft stripper from a local auto body store. And wear a respirator mask while I apply it!
maggieevans is offline   Reply With Quote
Old 05-18-2014, 11:55 AM   #7
1993 25' Excella
CLeveland , Ohio
Home Depot Stripper
Good luck!
I went to Home Depot to buy stripper thinking you were talking about a house brand named Home Depot Stripper. No such thing. WHat was the name of the actual product you bought? Thanks!
Akronguy is offline   Reply With Quote
Old 05-18-2014, 01:34 PM   #8
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Citrus Strip
Works great, smells great, cheep.
Silver Hawk is offline   Reply With Quote
Old 05-18-2014, 10:26 PM   #9
1969 27' Overlander
Klean-strip is the brand. They also claim to be America's number 1 stripper brand. Who doesn't?
Anyways I apply it with a natural hair brush which works much better than the spray bottle that comes with it. Wait a few minutes per the directions then power wash it off.
Cheers
Old 05-21-2014, 08:18 PM   #10
streamslave's Avatar
1967 28' Ambassador
Gatlinburg , Tennessee
It seems that one of my panels have a newer replacement panel... Can newer panels be polished to a mirror finish like the vintage panels?
streamslave is offline   Reply With Quote
Old 06-04-2014, 09:44 AM   #11
1984 31' Excella
West Jordan , Utah
I didn't have good luck Eldorado PR-5044 product. It was too slow and due to how slow it worked it dried out quickly in the Utah sun. Other strippers are more easily available and less expensive as better alternatives. Examples being Citri Strip and Aircraft Stripper.
________________
Cliff Bates
Currently renovating an 84' 31 Excella
See it at batesairstream.blogspot.com
cliffy23 is offline   Reply With Quote
Old 06-06-2014, 04:27 AM   #12
1976 25' Tradewind
1959 22' Flying Cloud
Mineral , Virginia
Clear Coat Stripper
Aircraft Stripper is the ONLY way to go in my opinion! I bought the citrus stuff...no luck! The aircraft stripper worked instantly! Just about finished stripping my 31 footer with this and some plastic putty knives and mineral spirits.
Mrhany is offline   Reply With Quote
Old 06-09-2014, 08:21 AM   #13
1993 25' Excella
CLeveland , Ohio
We have 90 % of the clearcoat removed. Aircraft Stripper bought at Advanced Auto Parts here in Akron did the job. Tried citrus stripper and it took forever.
Old 06-09-2014, 09:01 AM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I used Citristrip gel, it worked fine. It is a little slow dissolving the finish, but it did not burn my skin. It's non flammable and less volatile, so it is much safer to use and not likely to cause breathing issues. And, it is biodegradable, so not as harmful to the environment as some strippers can be. The only issue I had was that it did not stay wet as advertised, it dries pretty quickly when used outside in the breeze. When it dried I had to apply more stripper to get the first stripper off.
Alan
A W Warn is online now   Reply With Quote
Plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 23 10-21-2011 11:25 AM
Clearcoat Removal equigley Cleaning, Stripping & Polishing 23 04-27-2008 10:35 AM
Polishing : 1st step - clearcoat removal dufferin Cleaning, Stripping & Polishing 24 08-03-2007 01:51 PM
Clearcoat rust removal - How? TomW Cleaning, Stripping & Polishing 10 07-02-2004 01:32 PM
Clearcoat scratch removal mcostanzo Clearcoat, Exterior Paint & Trim 3 07-01-2003 09:28 PM
