Old 06-30-2014, 05:41 PM   #29
reinergirl's Avatar
Hollis , New Hampshire
Originally Posted by lakoria View Post
Still working on getting the 68' overlander stripped. It's coming along well but the top panel is not doing as well as the bottom. Do you think the clear coat is already gone or what?Attachment 215021Attachment 215022
Take a bit of polish, even toothpaste in a pinch, and rub a small patch on the upper if it goes black the clearcoat is already gone, polish away .
reinergirl is offline   Reply With Quote
Old 07-01-2014, 11:42 AM   #30
1989 25' Excella
What areas do you tape off or need to protect when using stripper? I am now determined to strip my 89 25ft Excella. Did the decal come off with stripper used for clearcoat?
PAL07 is offline   Reply With Quote
Old 07-02-2014, 06:55 AM   #31
1993 25' Excella
CLeveland , Ohio
We used plastic film to cover windows and plastic shields. We took off all lens (Brake lights and other reflectors) and then taped over the holes. The decals were the toughest to remove. Ot took 3-4 applications of stripper to remove them.
The plastic film we used was the temporary carpet plastic in a roll that is used when someone is working on your house. I bought it at lowes. It stuck on the glass and peeled off weeks later with no problem.
Akronguy is offline   Reply With Quote
Old 07-02-2014, 09:10 AM   #32
1969 23' Safari
fairfield , Pennsylvania
polishing
Miller,
condition of skin was ok it is a 1969 safari. no really bad spots The aircraft stripper is really strong stuff do no get it on your skin, it burns. Pretty pricey about $15.00 a quart
russellsue is offline   Reply With Quote
Old 07-02-2014, 09:27 AM   #33
1989 25' Excella
Akronguy, what about the two blue 3/8 inch bands above and below decal? Also the 1 1/4 inch band at the base? These appear to be plastic, so do I need to cover these at stripping with this product?
Old 07-19-2014, 06:48 AM   #34
1973 31' Sovereign
Milton , Delaware
I like the Non Flammable Methylene chloride paint stripper
rjpapp is offline   Reply With Quote
Plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 23 10-21-2011 11:25 AM
Clearcoat Removal equigley Cleaning, Stripping & Polishing 23 04-27-2008 10:35 AM
Polishing : 1st step - clearcoat removal dufferin Cleaning, Stripping & Polishing 24 08-03-2007 01:51 PM
Clearcoat rust removal - How? TomW Cleaning, Stripping & Polishing 10 07-02-2004 01:32 PM
Clearcoat scratch removal mcostanzo Clearcoat, Exterior Paint & Trim 3 07-01-2003 09:28 PM
