Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 04-23-2003, 05:30 PM   #1
art
Profile:
clearcoat -plasticoat stripper
going to polish the old girl . got the nuvite ,cyclo,buffer,ready to go .what is the tried and true stripper? any advise?Tried this jasco sealer and ahesive remover in a spot. dont care for it .It leaves too much behind.
art is offline   Reply With Quote
Old 04-23-2003, 06:22 PM   #2
amfab
Profile:
People seem to like Citristrip, ( www.citristrip.com/ )
but to me it seemed too cumbersome to get off all of it. I Like Stripeez ( www.savogran.com ) it washes off with water. Not that you would want to hose all of it off into your yard, but you can wipe off the easy big gloppy stuff and then wash off the remaining film. I havent got into it much just started the stripping a bit ago and had to stop for other things. They both took the stuff off - I just got frustrated gettin the citristrip off afterwards. Its like cleanin up an oily melted orange popsicle-but its toxic. Someone I know uses Klean-Strip ( www.kleanstrip.com/ ) the KS-3 Premium Stripper and he says it worked fine.
Thats my 2 cents and I'm sure there will be more comin from others
-Andrew
amfab is offline   Reply With Quote
Old 04-23-2003, 06:50 PM   #3
airstreamcaravel
airstreamcaravel's Avatar
Profile:
Stripping Clear coat
A previous thread
Have fun ... I did!
DMC
airstreamcaravel is offline   Reply With Quote
Old 04-23-2003, 09:47 PM   #4
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
I use the Jasco Epoxy and Paint remover and it works like gangbusters.One thing to consider is the temperature and brush.ALWAYS shake the stripper regularly before pouring from the can and work with small amouts.The only active ingredient in good strippers is methylene chloride.The other ingredients are surfactants and wax to control evaporation of the volatile M.C.The temp. should not be too hot (evaporation) and too cold will retard the action.Your brush and technique will make a big difference in whether you get it all off.Use old brushes that are soft bristle and you can afford to loose.Lay the stripper on with minimal strokes and generous material.Don't try to work more than about a 3 foot square area.Work from top to bottom-that way you can move the used material over a new area and get more mileage out of it.I use a sponge with a scotchbrite side to it ,with a wash solution of water, ammonia and dish soap.Starting at the top I wipe the dissolved finish in a horizontal "squeegee"type motion moving the material progressively down and over the next area.You can then begin to see any dry areas and hit them with the scothbrite or move some stripper over them for a few more minutes.A second wash down will usually give you bare metal.The soap and ammonia cut the wax.Avoid too much "scotchbriting"as the object is to end up with the "factory "skin avoiding an extra polishing step.
A 24ft.trailer should cost you about 1 to1.5 gals of Jasco and do't forget the nitrile gloves-the stuff really burns!!
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 04-23-2003, 10:15 PM   #5
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Creampuff is right on, it is still work anyway you slice it!! I made it sound too easy on one of my posts. I usually go over an area at least twice with the stripper routine. If you think it will all just magically slide off with the hose you will be disappointed.
Chas
Chas is offline   Reply With Quote
Old 04-23-2003, 11:31 PM   #6
Forrest
Forrest's Avatar
Profile:  1966 20' Globetrotter
1986 32' Excella
Aurora , Colorado
Images: 21
Lightbulb Clearcoat remover
You might consider Aircraft Coating Remover found in Checker Auto among other places. You can buy it in the can to brush on or in an aerosol can to spray on. I like the aerosol, more expensive, but not as much waste and easier to use. Be sure to wear an old long sleeve shirt cause if a breeze catches some of the spray and it blows back on bare skin it stings like nettles.
Forrest is offline   Reply With Quote
Old 05-06-2003, 01:57 PM   #7
joe hall
Profile:  1986 31' Sovereign
Lenox , Georgia
Murray (Creampuff), you indicated.......
water and ammonia would cut the wax. I once read somewhere in this forum that ammonia should not be used on an Airstream skin. Did you notice any particular problems? Thank you for your reply.
joe hall is offline   Reply With Quote
Old 08-18-2003, 08:31 PM   #8
jthew1
Profile:
Paint Stripping Health Hazard
"The only active ingredient in good strippers is methylene chloride"
I've monitored this forum for some time, but decided to register and post today in the hopes I might save someones health/life.
I've reviewed dozens (maybe hundreds) of posts regarding paint stripping with various products. But, I believe the above quote says it all.
Methylene Chloride (CH2CL2) is a KILLER! The US Department of Health, National Institute for Occupational Safety and Health, Guide to Chemical Hazards indicates that:
The permissible exposure limit is 500 ppm (parts per million)!
Is is Immediately Dangerous to Life and Health (IDLH) at 2200 ppm!
It is a Carcinogen (cancer causing) chemical!
It is incompatible with active metals, such as aluminum!
Skin and eye contact must be prevented AND a positive pressure, full face, self contained breathing apparatus must be worn.
I for one, will leave this task to the experts (regardless of the cost) and suggest others might want to consider the same.
This is a great site with a knowledgeable group of people. I thank you for the personal insight I have gained from viewing your posts. I hope mine will be of similar value to you.
Regards
jthew1 is offline   Reply With Quote
Old 08-18-2003, 09:36 PM   #9
drboyd
drboyd's Avatar
Profile:
Really! I just stripped the glue off my concrete patio (carpet was glued down by previous owner of the house) with a JASCO glue stripper, and you can tell by looking at it that it's like The Most Toxic Substance Known to Man. I felt like unborn babies three miles away started growing five extra legs the moment I took the top off the can...
Old 08-18-2003, 10:32 PM   #10
trailertrash
Profile:
Citristrip-
Less toxic, and you have to leave it on longer than they say. I like to put it on with a paint roller out of a pan- gobs of it! Then take it to a self serve car wash- use their high pressure, as well as their drain. No sense in having it all over your yard. The pressure takes the residue off pretty well.
Before you get started- check out safari tims plea for help- he's experiencing the "psychlo journey" as well...
trailertrash is offline   Reply With Quote
Old 08-18-2003, 10:53 PM   #11
jthew1
Profile:
Paint Stripping Health Hazard Continued
"One thing to consider is the temperature --- other ingredients are wax to control evaporation of the volatile M.C. The temp. should not be too hot (evaporation)"
The (volatile) Methylene Chloride boils and becomes a gas (evaporates) above 104F. Consider the "skin" temperature of an Airstream on a sunny day, not necessarily the air temperature,
Most members in this forum and manufacturers recommendations address the dermal hazards of these products in a liquid form, but overlook the inhalation hazards in a gaseous form.
A chloroform-like odor indicates that the M.C. is volatilizing and one should be on a supplied, positive pressure, full face, self-contained-breathing apparatus (SCBA).
Creampuff, please do not think I'm trying to "bust your chops" or "flame" you in any way by quoting from your post. I am only trying to be of help to the under-informed members of this excellent forum.
Old 08-18-2003, 10:59 PM   #12
trailertrash
Profile:
One more caution-
To go with the health hazards pointed out jthew- check for hydroflouric acid- it eats aluminum and if not thoroughly removed- which is next to impossible around loose older rivets- it can weaken the affected area and cause headaches later- usually much later but, still.
Same chemical should be avoided when acid washing- aircraft approved acid washes are free of this particular acid.
Old 08-18-2003, 11:22 PM   #13
jthew1
Profile:
Re: One more caution-
"check for hydroflouric acid--- it eats aluminum and causes headaches later, usually much later"
Yes, and it eats people and causes brain damage (usually much later), too!
This is what got me started on the subject. I used a (NAPA) hydrofluoric acid spray aluminum wheel cleaner and got an unpleasant reaction (me, not the wheels, they looked great).
Check out this Environmental Protection Agency notice - very scary!
http://www.epa.gov/grtlakes/seahome/...use/alumcl.htm
Old 08-19-2003, 08:34 AM   #14
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
I'll chime in only from the "doctor side" here and say that methylene chloride IS a risky thing to use -- BUT, if you're using it outside in a well ventilated area, you're probably OK without the SCBA.
The reason MC is a bad thing thing for us is that our liver metabolzes it into Carbon Monoxide! Note: Your liver does this. Your wall detector won't find CO hanging out while you're using it! Hours later, long after you're done, the symptoms will start. If you feel headache, nausea, shortness of breath, chest pain, or decreased level of concisousness--call 911 first, then a regional poison center and tell them what you were using and inform your health care providers.
The key to preventing inhalational exposure is to work in a WELL ventilated environment and avoid getting too close to your work. Avoid dermal (skin) exposure by wearing appropriate gloves, eye protection, etc.
Most of us probably work on our trailers outside in the driveway. But this is key information to remember if you're using this substance inside. It's very risky...take appropriate precautions and remember the worst side effects are delayed!
I could tell you stories about HF, too...bad stuff!
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 07:36 PM
biodegradeable clearcoat stripper? Rog0525 Cleaning, Stripping & Polishing 3 01-23-2004 07:46 PM
Clearcoat choice? TomD32 Clearcoat, Exterior Paint & Trim 4 09-23-2003 05:16 PM
'92 paint vs. clearcoat fangthorpe Clearcoat, Exterior Paint & Trim 1 06-22-2003 11:23 PM
Plasticoat vs. Clearcoat spray...?? HappyChi Clearcoat, Exterior Paint & Trim 9 08-12-2002 07:13 PM
