Old 04-26-2010, 07:39 PM   #1
1969 27' Overlander
Springdale , Arkansas
Images: 21
clear coat removed now what?
95% is clean but water spotted, besides a new clear coat what kind of polish will help keep the trailer looking clean and repel water spotting ?
Foundtruth is offline   Reply With Quote
Old 04-26-2010, 07:52 PM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Now What?
You can get a bunch of info on polishing your trailer from Vintage Trailer Supply...now the fun starts....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 04-27-2010, 08:19 AM   #3
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
What did you use to remove your clearcoat and did it effect the plastic parts?
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 04-27-2010, 04:46 PM   #4
1969 27' Overlander
Images: 21
We tried AIRPLANE striper on the blue stripe and the Number Stickers above the Clearance lights. It removed most but it did damage the plastics...luckily we were going to be changing all the lights!. We applied Smart Strip on the body and left it overnight. It removed most except a few areas a second coat took care of the rest. Our 27ft we used 3 buckets at about $60 each. The SmartStip didn't seem harsh on skin, My 5 year old helped apply it also. Then in the morning we power washed it off.
What we have Now seems to be oxidation or something but it doesn't seem to be the clearcoat. On the other side of the trailer it is perfect. This photo is before the second coat was applied to the roof.
We don't want to Polish it to a Mirror finish....
ID:	101404   Click image for larger version
ID:	101406   Click image for larger version
Old 04-27-2010, 05:50 PM   #5
VIKING's Avatar
Boulder Creek , California
The dirty looking area may be from having something rubbing against the surface, though it doesn't look quite like a rubbed area typically does. Usually there is a curved pattern it the discolored area due to having something like a branch or a tarp brushing back and forth against the surface.
You said you don't want the really shiny look. In my experience, which is quite limited, if you only polish it to a low sheen you will have swirl marks that will re-appear as the surface oxidizes. I have seen an Airstream that was just compounded, not polished, and it had a lot of that funhouse mirror effect going on. I have heard of an acid process that might be a better way to approach yours. It apparently doesn't give you as shiny a surface as polishing does, but it doesn't need quite the several hundred hours of labor, as polishing does. I'll try to find info on it for you.
Rich the viking
VIKING is offline   Reply With Quote
Removed the clear coat...what now? papagord Cleaning, Stripping & Polishing 19 04-27-2015 03:58 PM
Clear Coat not completely removed RichHog Clearcoat, Exterior Paint & Trim 0 05-27-2009 11:05 PM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 08:13 PM
clear coat peel joel Clearcoat, Exterior Paint & Trim 1 11-21-2005 10:30 AM
Clear Coat/ Plasticoat tmeagle1 Clearcoat, Exterior Paint & Trim 0 08-21-2005 03:37 PM
