Old 07-31-2014, 01:54 PM   #1
1968 24' Tradewind
omaha , Nebraska
Clear coat not coming off after 2 tries :(
I applied a coat of Aircraft Paint Remover and then power washed 15 minutes later and got some of the clear coat off. I did it a second time and not much of the remaining came off... What should I do as the unit looks terrible
Can I wipe it down with lacquer thinner to get the rest off?
rothway is offline   Reply With Quote
Old 07-31-2014, 02:15 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Reapply the stripper, let it sit longer, even a couple of hours (or more) if needed.
You can cover the stripper with saran wrap to allow it to stay moist longer and work stronger.
You are now committed to the project.....
Anyway, you will also find that the stripper works much better out of direct sunlight.
Old 07-31-2014, 03:12 PM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Gotta agree here with J. Morgan, give it more time. If it is like most strippers, it contains parafin which skims over to keep the actual solvent underneath from flashing off. Don't brush it back and forth like paint, daub it on thick, then take a break. Let it do it's thing.You can even reapply it on top of the first round if need be.
No doubt about it, a tough and labor intensive job. Good luck.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 07-31-2014, 03:36 PM   #4
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Don't be discouraged right away. I don't know one stripper from another. The variety is endless as to what to use. In my case I bought off the shelf at Home Depot a product called Klean Strip KS-3. BTW, I am not endorsing Home Depot, they just as happen to sell what I bought at the time. As said in prior post the key is to give the product a reasonable chance to work what ever you use. We are all anxious to have it DONE! Well, patience is also another key. It does come off. My way of removing was to apply the stripper wait the reasonable time, maybe reapply over, then using a sharp plastic scraper slowly remove the clear coat. Plastic scaper as not to scatch the aluminu.Also I am just removing the clear coat from the upper area above the bumper rail. So the need for protecting the lower area is important. A wipe with paint thinner will remove the remaining residue from stripping. Good luck, it does come off! Sorry if this post is too wordy but I am tring to make a point and be as clear as I can be.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-31-2014, 06:16 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Yep, just recoat and try again. It'll eventually take it all off. Along with splotches of your body's outer covering, as noted in the instructions on the can. Just don't get it in your eyes.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 07-31-2014, 06:22 PM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
It took us several applications of stripper and power washing to finally get all the clear coat off. By several, I mean 5 or 6. More came off each time, so that gave us the incentive to keep going. Plus, once you start, it just looks ugly until you get it all off. We tried several different brands of stripper, and aircraft stripper works about the best of all of them.
Chis
Old 07-31-2014, 06:40 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
There are two varieties of Aircraft Remover, regular and "low odor", you don't want the low odor stuff.
Old 07-31-2014, 07:03 PM   #8
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Some of the clear coat may be gone already
When we stripped the clear coat off of our Safari, there were some areas where there was no clear coat left to strip. The sun had destroyed it completely.
In those areas, the aluminum had oxidized to a color that looked almost exactly like the old, dead clear coat.
If the stripper does not cause the clear coat to bubble up and loosen after a reasonable time, wash the stripper off and try polishing the area. If polishing works, the clear coat is gone.
Old 07-31-2014, 07:11 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Great point. My 72 had perhaps 5% of the clear coat left.
Old 07-31-2014, 07:55 PM   #10
1964 24' Tradewind
Lawrence , Kansas
Just a word of caution about lacquer thinner while it will cut almost anything it has a very low flash point. I once had one of my paint crews burn down a house with lacquer thinner and the flip of a light switch. I use it a lot but always with due caution.
ttbikes is online now   Reply With Quote
Old 07-31-2014, 08:10 PM   #11
Swahealy's Avatar
1972 31' Sovereign
Valparaiso , Indiana
For the ignorant can someone please tell me what the clear coat is and why it needs to be stripped off? And why it's such a PITA. Was it some sort of finish applied to AS that prevents you from restoring a mirror shine ?
Swahealy is offline   Reply With Quote
Old 07-31-2014, 10:41 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes.. It is a plastic protective coating applied at panel manufacture (Alcoa).you must remove it in order to polish the aluminum. Or you can repair the coating is damaged and NOT polish the aluminum... Once polished, you must keep polishing...forever... Or it will oxidize... Not pretty
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-31-2014, 11:17 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I knew I had read somewhere that the coating on early trailers was a lacquer....
http://www.vintagetrailersupply.com/...advice0707.pdf
I am not sure,,,, kind of an educated hunch,,, but I thinks that the alclad trailers were coated after shell assembly.
Old 08-05-2014, 09:30 AM   #14
1968 24' Tradewind
omaha , Nebraska
Clear Coat Came off :) Now can I use Micro Glaze?
Great news and thanks for all the advice! by applying the Aircraft paint remover in the early morning out of the sun and applying generously and in a horizontal brush direction, opposite of before, we got all the clear coat off!! We also used towels to agitate the clear coat after painting in problem areas.
So, I am looking at using a Micro Glaze to help remove roof oxidation and do a quick option to protect the bare aluminium. I would apply with brushes then hand polish off with rags... I don't have time to use buffers and just want to get the black spots off the roof and kind of protect the bare aluminum. Any thoughts on this idea????
thanks,
Maintenance after new clear coat wascoman Cleaning, Stripping & Polishing 1 01-27-2013 03:52 PM
Newbie Tries to Deal with the 'Icky Stuff' ... Fly at Night Our Community 9 07-11-2011 08:04 AM
Clear coat removing & after sanding questions! Sayyar Clearcoat, Exterior Paint & Trim 1 10-04-2009 09:13 AM
Clear coat flaking not a problem with 2003 or later models? bgowen Clearcoat, Exterior Paint & Trim 7 03-16-2009 11:48 AM
Clear coat coming off the top tslanier Cleaning, Stripping & Polishing 1 06-13-2006 09:02 PM
