Old 08-27-2016, 12:13 PM   #1
PJA
1965 17' Caravel
bloomfield hills , Michigan
Smile clear coat
Hi everyone,
I am a newbie and have just bought a 17' Caravel. I've had two Class B motorhomes and have decided to pull from now on. I'm working on the inside, but have been wondering about polishing. Mine is a 1966 and no work has been done to it, so do I assume that there is a clear coat that must be removed before polishing begins and how do I tell? Thanks
HAPPY TRAVELS
PJA is offline   Reply With Quote
Old 07-31-2017, 08:10 PM   #2
1966 17' Caravel
marquette , Michigan
I see this is almost a year old thread but here i go. I also have a 66 caravel and the prior owner had the clear stripped off and polished before i got it. The clear cracks and hazes with age and during the polishing if the clear is still there you won't get a black film on you polishing cloth. If that is the case you will need to strip it off. Good luck.
MI66caravel is offline   Reply With Quote
Protecting Plasti-coat / Clear coat John&Vicki Exterior Restoration Forum 2 08-08-2016 08:41 PM
Is it clear coat or clear film? TankerIP Clearcoat, Exterior Paint & Trim 14 08-08-2016 03:27 PM
remove clear coat and re coat one panel at a time. Bill M. Clearcoat, Exterior Paint & Trim 7 08-01-2016 02:37 PM
clear coat or plastic coat fpoulson Cleaning, Stripping & Polishing 1 10-26-2014 12:42 PM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
